Question about SI-TEX Sitex Cvs106lmkii Color Lcd With 236/50/200st Tm Triducer Model
Want to know depth range just bought boat with this unit know nothing about it
    New Friend:
  • 132 Answers
With the correct transducer you can mark fish at 600 and bottom at 100 feet
Posted on Jan 31, 2010
Won't work over certain speeds
Think of where the transducer is fitted on your boat . As turbulence is the only problem you need to worry about. It needs too be on the transom but in between the lower 2 chines
Apr 17, 2012 | Eagle Fishmark 320 Portable Fishfinder
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
I have a fishfinder Hummibird 565, I use it on a big fishing boat which is impossible to fix the sensor on the bottom of the boat, so I tried to hang it on the boat with a float, but it cannot work well,...
you can get a specialist to come and fix/reapply the sensor to the boat and possibly fix it if it is broken var fctb_tool=null; function FCTB_Init_4fdf0f4e4d1b403489dd188ff9311fa0(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_4fdf0f4e4d1b403489dd188ff9311fa0(document['FCTB_Init_3475a15565eb478ea69972d3c6d88377']); delete document['FCTB_Init_3475a15565eb478ea69972d3c6d88377'] var fctb_tool=null; function FCTB_Init_a70c5362962d40be976e65b2158646e3(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_a70c5362962d40be976e65b2158646e3(document['FCTB_Init_379c2b6472d1424f847e6d43703fa3ad']); delete document['FCTB_Init_379c2b6472d1424f847e6d43703fa3ad']
May 05, 2011 | Sport & Outdoor - Others
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Jul 28, 2009 | Boating
Bought a 1995 Four Winns boat inthe dash it has a lowrance dept finder. under dash i see a 6pin male round connector & 2 pin round male hareness is there a harness i need to connect the 2 or what would...
Hi- I have a 1996 Four winns boat with the same problem. I believe we are missing an adapter cable which goes from the depth cable to the instrument panel. I have not been able to locate this cable yet. If I find it I will let you know and can you do the same for me if you locate one?
Jul 03, 2009 | Lowrance Boating
Lowrance lms 330
have a lowrance lms-330c the depth no. keep changing from hi no. to low no. can not stop it,,, will not show true depth,,, can you help?,,,where can i send it to get it fix?
May 29, 2009 | Lowrance LMS-330C GPS Receiver
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
NO DEPTH READING
Check the finder on the bottom of the boat and make sure the cable is ok?
Aug 09, 2007 | Garmin 185 Sounder GPS Receiver
SI-TEX Sitex Cvs106lmkii Color Lcd With 236/50/200st Tm Triducer Model Logo
73 people viewed this question
Top SI-TEX Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a SI-TEX Boating Expert? Answer questions, earn points and help others
