My hotpoint wma32 wont empty - Washing Machines
Chances are you have a lid switch problem or the most likely cause could be a drain pump obstruction.You could use a wet dry vacuum and connect it to the drain hose in the back of the washer to empty the water.Once the water is empty remove the hoses that are connected to the drain pump and feel for the obstruction in the pump.If nothing in the pump,it would be the lid switch.
Posted on Jan 31, 2010
Leaking water from inside front
clean the glass inner door @ the bottom. one strand of hair can cause it to leak. if that wont work inspect the bellows (door seal)
Sep 19, 2013 | Hotpoint WMA32 Front Load Washer
The only problem I have is I need to know how much weight this washer takes - Hotpoint WMA32 bought in 2003
Page 11 of the manual states that tha maximum load is 5.5Kg cotton
Recommended load for synthetics is 3Kg
If you need a copy of the manual, you can download one here:
http://www.espares.co.uk/datastore/ProductManuals/899126.pdf
Sep 21, 2011 | Hotpoint WMA32 Front Load Washer
I need an instruction manual for Hotpoint WMA36 Washing Machine
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Here is a link to the page you need.You will need the model number.
May 13, 2011 | Hotpoint WMA32 Front Load Washer
Washer will not empty
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2010 | Hotpoint WMA32 Front Load Washer
The condtioner draw
Dilute your conditioner with water while pouring into drawer.
Apr 07, 2008 | Hotpoint WMA32 Front Load Washer
Drum??
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. If all this doesn't work check your pump(may be clogged), refer to manual.
Rate me pl.....if helped.
Jan 12, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint WMA32 Front Load... Problem:
if its not your belt its the brushes in the motor that need replaced i would replace the brushes first the cost about £15-20
Jan 04, 2008 | Hotpoint WMA32 Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
