Question about Maxent Televison & Video
Remote BRC-257SE inop No light with any button; new batteries. Tried removing batteries and pressing all buttons to no avail. Prior to unit dying, sometimes it would "hang up" with red light on, and no action from any button.
Problem solvede; ordered a new one (monitor).
Posted on Feb 01, 2010
Standby light blinking
If you can't turn it on with the on button on the tv its not the remote causing issues. Are you able to pull the back off it and take some voltage measurement readings/
Dec 07, 2017 | Televison & Video
Remote inop
Step 1:
Have thee remote tested--most shops will do this for free--point remote at the tester and it will react when buttons are pressed on the remote.
Step 2:
A digital camera in many cases can also be used for this---in a very dark room point remote at the camera with the camera on---press buttons and look for a tiny flash of light on the camera display screen.
Step 3:
If remote tests bad it can usually be taken apart and fixed OR you can opt for a new remote---I would avoid universal remotes as they often if program will be missing key and needed button/features.
In our shop we fix remotes with a 10 dollar max price--lots we fix for free.
Step 4:
Last but not least if the remote tests good the remote receiver inside the front of the set may be bad and a shop would have to replace that unless you are able.
Here is a photo of the typical receiver (less than 1/2 inch tall part).
Dec 06, 2012 | GE 27GT620 TV
I have a Samsung LN40c530F1F and I accidentally pressed the button below the power button labeled "DVD receiver/TV" and now nothing works at all on the remote. I have tried re-pressing the...
Take the battery out like about hour for a hard resetting.After putting the battery back in u should push the button that said TV only.The remote should be functions again for the tv again.
Jun 18, 2011 | Samsung LN40C530 TV
Tv Remote stop working already tried new batteries, also tried programing univers remote can't find electron so I tried curtis mathis codes and still can't program remote one work but would not turn of or...
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
Feb 28, 2011 | Televison & Video
Reprogram keypad remote
Setting the code:
1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal indentification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Apr 25, 2009 | Computers & Internet
Dino Buddy not responding to r/c
I Replaced the batteries in the dinosaur, because mine did that after only a few hours. when the batteries start to die, only the demo switch works...
I hope this helps!
Nov 29, 2008 | Lillian Vernon Remote Control Dinosaur...
Mitac mio 168 non charging problem
I sent my battery back and it was replaced by the supplier. The unit is fine now so the only conclusion I can come to is that it is due to a faulty battery....
Jan 18, 2008 | Mitac Mio 168 Pocket PC
Battery died and need to set up codes for Fisher TV
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3021
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Jan 06, 2008 | One For All URC-3021 Remote Control
Dish Network remote control unit malfunctioning problems
Hi Monell56 my name is Mike Houston of DISH Network, with the DISHNetwork remote and replacing the batteries in the remote you will press andrelease the SAT button and press select on the remote. If the SAT button didnot light up the remote will need to be replaced. If the SAT button lights uphere is the link that will help setup the remote. http://www.dishnetwork.com/SupportSection/remote-setup
Dec 04, 2007 | Televison & Video
Televison & Video Logo
108 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
