Question about Kitchen Ranges
Can I put a 35 watt bulb into a Rangehood?
Can I put a 35 watt, 12V bulb into a Smeg IS250 island canopy range hood?
It previously had two bulbs which were 20 watt, 12 V.
  • schrier_shop Jan 31, 2010
    Thank you very much. Most helpful.
    Hi there
    I figured out what you meant! My original qn was misleading though. I am replacing 2 x 20w bulbs, with 2 x 35w bulbs. Still ok you reckon?
  • Kitchen Ranges Master
  • 12,061 Answers
Yes it will possibly just be a little brighter... but should do no harm. The original 2 would equal 25 Watts the replacement 35 Watts.. the 5 Watts in neither here nor there.
Posted on Jan 31, 2010
Testimonial: "Thank you very helpful, and prompt"
  • electronic & computer repair&  servicre
    Hmmm my math was wrong...The original 2 would equal 25watts should have been 40Watts,not 25..
How do i replace the bulb in a Smeg rangehood?
I WOULD MESS WITH IT TAKE IT TO A GARAGE THAT DO ELECTRIC WORK
Mar 03, 2015 | Smeg Kitchen Ranges
Left turn signal doesnt work
its a bulb or a dodgy contact to a bulb ,12v 21watt bulbs not a 12v 6 watt bulb or it will flash faster
Mar 08, 2014 | 2000 Dodge Ram 1500 Truck
How to change the light
There are three different models... two wall models (the WL24 and the WL36) and an island model (the IS24). The instructions for changing the lights on all three models are the same.
Light bulb:
  • Make sure your hood is disconnected from the main power supply.
  • You may see a screw at the edge of the light cover. Unscrew it and remove the light cover.
  • Replace the light bulb with the same model as the original. There may be a decal near the bulb that indicates its rating. Don't exceed 25 watts! It's best to bring the old bulb to your store to have it replaced exactly.
Spotlight:
  • If you don't see a screw, then - using a screwdriver - lever the support ring, then grasp it & pull it straight down and off. This ring supports the glass cover - remove it as well (don't drop it!).
  • Replace the lamp with the same type (12V, 20W, G4 fitting).
  • Replace the glass cover and the support ring - it should snap back in.
Fluorescent light:
  • This needs to be changed by a qualified installer. Don't attempt it yourself.
Mar 02, 2011 | Futuro Altair Kitchen Hood
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
GE Deluxe 30 Range Hood ---can't find a 2 way bulb (Light/night light)???
The current Convertible Deluxe rangehood from GE doesn't support a two-way (light/night light bulb). You can use an incandescent light with an A15 type (60 watts or less) or a compact fluorescent (A17 or T2) with an ordinary screw base that draws no more than 13 watts. Some models can only use the incandescent light (RN328, JN327, JV338). The recommended compact fluorescents are available from www.gelighting.com (product codes: 85383 or 47486). Check you manual or products.geappliances.com for a pdf of your manual.
I wish that I could be of more help.
(the model of your range hood would be useful to get more information)
Jul 09, 2010 | GE Deluxe 30" Convertible Range Hood -...
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
I'm trying to change a light bulb in napoli zepher hood. I can't seem to unscrew the old bulb....what do I do now?
Standard bulb? Make sure the power is off. Put on a glove and keep trying. If you end up breaking it, try a screw driver into the base. No luck, you can get a replacement lamp holder at a appliance parts or hardware store. I have a tool designed to remove the broken base, but that does you no good and I dont know if they are made any longer. I got mine in '64.
Your lamp has been in so long, it baked itself into the socket (grease, etec)
Oct 26, 2009 | Zephyr Island Hoods: Napoli Island Hood
Light broken
Lift out the filter and access the bulb from inside.
Jul 29, 2009 | Smeg KSED65X-1 Kitchen Hood
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
