Goto the start menu. In the search bar along the bottom type: CMD
a black command prompt will open. In that command prompt type: net stop spooler. It should say, spooler service stopped. Then type net start spooler. It should say, spooler service started. Try reinstall. If you haven't deactivated the UAC controls, then ensure when you install to right click on the installer and left click on "Run as Administrator".
Good luck
You say yo can't install the printer - then you say you have a document queued up as if the printer is installed? I'm confused? Have you tried installing a different print driver like the 1710 or 1720 - which should work also with your 1700.
