I am trying to put the washing machine back together. i had boughtthe supporting rods for the tumbler?? and i have 3 of them in, but the 4th one is connected to some wires and it doesn't look like the one that was previously in there. also, they don't have the spring coils that were on the ones that were in there.
  • 129 Answers
ASK BING.COM IT WILL BREAK IT DOWN STEP BY STEP TYPE IN MODEL #
Posted on Jan 31, 2010
Upon putting the machine back together, the door somehow now does not fit when closing.
The cabinet make of racked while you were working on it. Loosen the screws and gentle press it to the side that is off and re tighten the screws.
Mar 12, 2016 | Maytag Neptune Washing Machines
How do I adjust troy built lawnmower deck. Front bar attached. To deck came off and trying to put it back on
I think the way it looks you will have to unscrew the bar and put it in the hole then put the part back together. You may have to move your base one way or another to do this as well.
Try moving your base up or down or side ways before you unscrew it as well You may have to just line it up to make it work.
Apr 11, 2015 | Troy Garden
Ge wjrr4170 no spin
Remove the front panel, then look at the motor to see what codes the motor is flashing. There should be a green light on the motor that will be flashing. Post back your findings.
Nov 13, 2012 | GE WJRR4170E Top Load Washer
How do i fit the drum suspension spring on my font loader ariston washing machine
If you have already remove the top cover, front cover and back cover of the washer. You can gain access to the bottom portion of the tumbler. There you can jack up the tumbler with a jack of some sort, so that the tumbler is higher easier to latch on the spring to the hooking holes and not have to struggle with the tension of the springs.thinkfixya.pnghen put them onto the hook holes.
Jan 10, 2011 | Ariston Technologies Washing Machines
I have a GE Front Loader. Model# GHDVH670H1GG. The tumbler works until water is required to be drained. At that time, the tumbler is trying to tumble for rinse, but, the water is not being drained and not...
On my machine the pump filter was clogged preventing the water from draining out of the machine properly. This would leave the clothes soaked in water as the machine tried to spin, the extra weight caused the drum to rub against the door seal while spinning, causing the burnt rubber smoke! I removed the 3 screws on the lower fron panel of the machine and opened the drain ( make sure you have a pan or bucket to catch the water! ) cleaned the fliter and put everything back. Works like new again. Good luck.
Sep 22, 2010 | GE WSXH208A Front Load Washer
Ge profile washing machine
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
Feb 18, 2010 | GE WBSR3140DW Top Load Washer
I have an original Maytage Neptune electric dryer (MD-6). The tumbler looks off-center from the seal at the back of the dryer and clothes have been getting ''pinched'' and eaten at the upper right-hand...
replace the rear support wheels and the felt . / good to replace the front slides and felt too . this should stop the problem / ck belt and idler as they also have some milage . mm
Dec 08, 2009 | Washing Machines
Hotpoint aquarius tumbler not turning belt was off so put it back on and still tumbler not turnig altho bottom motor is working
the belt didn't get put on the idler pulley and does not have enough tension to turn drum, recheck belt routing
Nov 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I do not know how to remove the top from my whirlpool washing machine to replace the lid switch
Unplug the machine.
There is a screw at the bottom of the console on each end of the machine, remove them.
The console should then lift up and roll over the back(just make sure its supported or suports its self).
At the center of the machine there is a white plug, for the safety switch, unplug it.
On each side of the machine there is a brass colored clip, use a flat screwdriver and insert it into the front of the clip, push back smartly, this will release the clip. PAY ATTENTION to the way the clip comes out. (which end is the front of the clip) mark things if your not too handy so it goes back together easly.
This machine is put together alot like a puzzle so paying alot of attention to what you do will alllow you to put it back together.
The whole cabinet rolls forward, the sides along the bottom sit on an edge on the bottom, but the front is hooked UNDER the bottom edge. try to notice this. as you rotate the cabinate the front will fall free after you rotate the whole thing over about 45 degrees. The back will kinda float.
Apr 08, 2009 | Kenmore 24032\24036 Top Load Washer
No runing
no working and no disply power
Nov 19, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
