Question about Amana ARB1905C Bottom Freezer Refrigerator
ICE MAKER IS NOT WORKING JUST STOPPED / TRIED MOVING TH E LEVER UP AND DOWN BUT NO LUCK
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
daffad
Posted on Sep 30, 2010
ICE MAKER STOPPED MAKING ICE,JUST GOT LAST WEEK,MADE ONE CONTAINER OF ICE THEN STOPPED
Try moving the ice maker shut-off valve lever 4-5 times. Move it up and down, or on and off. It tells the ice machine is full. You may be able to reset it. Look on the front. Do you have water out of the tap in front?
Apr 25, 2017 | Refrigerators
Just replaced filter. Now, why doesn't the ice maker work?
When the ice tray is filled, it lifts a lever to stop the process. Try to pull the lever down.
Aug 24, 2015 | Whirlpool Refrigerators
Not making ice
Probably dirt or hard water stopped up the supply tube bringing water to the unit. It's very small and doesn't take much to clog it up. Also make sure the lever in the ice making unit is down. If it made ice before and was full, the lever moved up and shut off the ice maker and now needs to be reset in the down position.
Jun 17, 2014 | Jenn-Air JCD2389G Side by Side...
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
My GE Profile ice maker has stopped making ice. It feels like there is ice in the tray but it doesn't drop into the ice bucket. Any ideas?
There is a lever that goes up and down to measure the amount of ice and shuts down the production if the lever is on high. Make sure the lever is down and see what happens 12 hours later. If you still don't have ice, it will need professional work. So call your service agent where you purchased it to get it checked if that happens ok. Good luck.
Jan 12, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
No ice
your unit may be having an issue with the Ice maker itself. The ice shut off lever on the side of the ice maker may be broken. If so the ice maker would have to be replaced. You can try to move the lever up and down( metal wire type lever) not much about half an inch or so.If you hear a real soft click its ok if not, time to replace it.
Jul 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker doesnt stop making ice
Check with an identical unit to see how that one moves. Yours may be dislocated. The lever arm probably contacts small plastic parts in the timer that could be out of place. Ice makers aren't too tough to take out and check out in a more comfortable work location. Just put a towel to catch screws.
Apr 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer not making ice in Fridgidaire model PLH269ZDB2
There is a lever in the ice bin that detects when it is full. if that lever is locked in the"up" position, the maker stops making ice. Many times a previous owner or a shipper will turn off the icemaker this way. especially if the water to the home or freezer is turned off, so it won't keep trying to make ice.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Amana ARB1905C Bottom Freezer Refrigerator Logo
85 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
