Question about Kenmore HE2 Plus Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
  • 5,911 Answers
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Posted on Jan 31, 2010
  • 438 Answers
Obtain a new door seal from any appliance repair depot that handles your make of machine and replace it
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
I have a kenmore HE 2plus. i am getting a f-21 error reading and door won't unlock, what is the problem and how do i get the door open?
f 21 usually means drain pump is bad. may need to check door lock an see if it reads 15 ohms across the output. if its more than 15 change the door lock
Jun 03, 2011 | Kenmore HE2 Plus Front Load Washer
Where do I find the serial number/ model number on my front loader?
If this is a Kenmore front loader, the serial number is on a nameplate tag around the door opening along with the model number. You need to open the door to see it. I hope this helps you.
Feb 04, 2010 | Kenmore 44072 Front Load Washer
Kenmore front load is leaking from the bottom.
Jan 23, 2010 | Kenmore 44102 Front Load Washer
WATER COMING OUT UNDER MACHINE
Is this a TOP LOADER? Or, is this a FRONT LOADER?
If this is a Kenmore TOP LOADER, you will need to remove the exterior washer case to inspect the cabinet interior thoroughly to determine WHERE the leak may be coming from. The following link explains:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The most common source of leaks on a top loader is a worn drain pump. If the pump is damaged and leaking, it is not serviceable and must be replaced. There is a follow-on link included that explains how to replace one.
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior. The following link explains:
If you have any questions about these repairs, please post back with your complete MODEL NUMBER (located on a nameplate around the door or tub rim) so that I may be able to provide you with better assistance. I hope this helps you.
Jan 18, 2010 | Washing Machines
My kenmore elite front loader leaks
well you can remove teh boootm acess panel by removingthe 3 screws that run along the bootm of the unit . afete rthat you can set a cycle to wash ans see where the leak is coming from
Jan 28, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
My front loader stops at every cycle. Is there a simple solution to this?
Jan 22, 2008 | Kenmore 44832 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
909 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
