Blank Screen
Moved House RE Packed LCD Screen in Orginal Packageing Transported with care Connected to PC Tower appears not to power UP
  • outdoor882 Jul 20, 2008
    have moved twice and each time the screen goes black says its in power save mode. First time dell replaced the monitor second time my warranty expired 3 days prior, no replacement told me to take it to a local tech shop
    Scholar:
  • 80 Answers
Hi
Pls check with another monitor or another comp to check if it is a problem with the monitor or with the computer.
If it is a problem with the monitor, get the monitor serviced.
If it is problem with the computer, check with the power supply.
If the power supply is working, then reseat the cable that goes from the power button inside to the motherboard. Also try reseating the RAM, CMOS battery and the video card.
If the above steps doesnt work, then the computer needs to be serviced.
Posted on Feb 18, 2008
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tip
CARE FOR YOUR PC MONITORS AND LAPTOP SCREEN
The monitor is a very essential part of the computer which plays a major role in displaying every data/ actions done by the computer in a way we can read, understand and appreciate with the use of colors, writings and drawings
TIPS ON PCS MONITORS AND LAPTOPS SCREEN CARE
* Do not place a magnet or any appliance that have a magnet close to your pc monitor because it will cause some color distortions to that part of the monitors that effect may not be reversible
* If the pc monitor displays “ NO SIGNAL “ on the screen or those not display any thing when booting , check the connection CABLE and make sure it is properly connected or change it if it is rusted.
* Do not place your monitors or laptops on tables with wheels to prevent accident.
* Do not spill solvents or liquids on your pcs monitors or laptop screens.
* To prevent radiations from your monitor always use the screen shield.
* Handle you laptops with care ,do not drop it or sit on it or press the screen.
* The laptop screen uses liquid crystal display (LCD) technology which makes them very fragile , always handle it with care because it is very expensive to replace a fault part.
* Store your laptops in well padded bags to prevent damage to it when it is being transported.
on Feb 22, 2010 | Computers & Internet
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
Jul 07, 2011 | Samsung BX2231 21 inch Monitor
I have a Dell Dimension 3100 which has recently moved house, and will not longer start up. The PC will switch on through the mains, but there is a series of 6 - 8 short beeping sounds, and the monitor...
I think you need to open the PC up and reseat the RAM modules, and the HDD cable and the CD/DVD cable too, make sure the power supply cable is secure too.
Also make sure you have the Video cable connected correctly too. Also the Keyboard & Mouse check them, they go color to color, also temporarily remove any USB connected devices. Connect them up after you have a desktop.
Those beeps usually indicate No Ram, or No video or both.
Sep 07, 2010 | Dell Dimension 3100 PC Desktop
My Dell Inspiron 1545 on Windows 7. After a system restore will not start. You switch on, The Dell logo appears, then the screen stays blank except for the cursor arrow which remains and can be moved...
Power drain your computer, remove all the accessories connected on it, including battery and power cord then press the power button for 1 minute.
Connect the power cord then turn on the computer.
This is a possible Operating system corruption and it needs a complete reloading of your operating system or reformat your HDD and install the OS again.
May 15, 2010 | Computers & Internet
Sony NWZB135F LCD Display is blank.
Not a Big deal !
maybe a capacitor is broken or a wire has been moved
And i wish it's not a total LCD break
Good luck
Nov 04, 2009 | Sony NWZB135F MP3 Player
I have a 42 inch spectroniq tv, i moved over the weekend, so i unplugged the tv and when i plugged it up at my new house, i just get the sound with a blank screen
I have a Spectronic LCD HD 42 "color screen is black with bright colors, sometimes does not look good, it lacks definition to see.
Oct 30, 2009 | Spectroniq PLTV-42HW68 42 in. LCD TV
VPR Matrix 226R-Blank screen when powered up,LED in front blinks
Not a power problem. Could a memory problem try changing the memory (DDR SDRAM), see if monitor comes on and if the system does a POST (power on self test) That should indacate any further problems if any.
Dec 06, 2008 | Matrix 226R (VPR226R) PC Desktop
Tower problem
the problem is your power button needs to be replaced or you can buy a new pc box on ebay for cheap.
Nov 02, 2008 | HP Pavilion 754n PC Desktop
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
576 people viewed this question
Alun Cox
David Payne
David Payne
