Question about Toshiba 51H93 51" Rear Projection HDTV
We had a power surge and now my Toshiba 51H93 will not turn on. I have unplugged it, hit reset button, any suggestions?
  • 110 Answers
Most likely your power supply has been damaged. Seek a repair service for this.
Posted on Jan 31, 2010
Computer wont turn on
Make sure the tower is getting power. There will be a green light on the back of the tower where the power cord goes. Make sure the cord is snug and that it is securely plugged in to your power source - I'm hoping it is a power surge strip and in which case, make sure the surge strip didn't get unplugged or turned off. If you have it plugged directly in to the wall then make sure that outlet has power by plugging something else in to it that you know works. After doing all of this, make check to see if there is a light on the back of your pc. If not, unplug the power from the back of the tower, wait 30 seconds at least, and then plug it back in. Hit the power button on the front just once, if it doesn't power up, press and hold the button in for a 2 seconds and release. If that doesn't work, your power supply may have gone bad. That happens from time to time. Good luck, hope this helps!
Jan 20, 2013 | Thermaltake Computers & Internet
I have a toshiba 51HC85. It will not power on the power button is flashing and we smelled a strong oder like something was burning
First is UNPLUG AND DO NOT TRY TO USE THE SET AGAIN.
Have someone who knows what they are doing open set now and look for burnt parts--the smell may lead you to the area where problem is.
Mar 28, 2012 | Toshiba 51H93 51" Rear Projection HDTV
Due to power surge tv will not turn on but stand by light is still on is it possible to reset or is it likley fried?
Try unplugging the power then hit the power button on the tv then plug it back in the wall and try to turn it on
Jun 21, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
Tv will not turn on even when reset button is pushed all you hear is a clicking noise
You need to replace the power supply on your set, this happen when horizontal output fail.
Dec 18, 2010 | Toshiba 51H93 51" Rear Projection HDTV
How do you reset a Ricoh 400N after a power failure?
Try pressing the power button for like 10 seconds until it completely powers off. And then try again to power it on.
If this does not work, do let me know to give you other suggestions.
Aug 17, 2009 | Ricoh Aficio CL1000N Printer
Toshiba 51H93 won't turn on **HELP**
Good Day, jsilver05;
That's a very good TV, sorry you're having a problem. I have the same TV.
1. The blurring of the pic may be an indication of a convergence problem.
2. The surge protector is not a fail safe device, it will reduce damage to the TV but will not not 100% protect it.
It is possible that by turning the power off may damaged the already weaken convergence circuit, but more then likely some other electronic device failed.Like a voltage regulator, high voltage device,and etc.
At this point I would recommend that you call a factory authorized service dealer and them come out and give you an estimate, or you can e me if want troubleshoot TV if you have digital meter etc.
Good Luck, big IRISH, mmrkcar@yahoo.com.
Jul 15, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Will not turn on
if main power supply is working check sub power supply.should be 1.5 volts on pe 42 pin8 and 9.
if missing replace ce36 and ce 39. i mounted mine caps on foil side.
May 20, 2008 | Toshiba 51H93 51" Rear Projection HDTV
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Tv struck by lightning
This set is pretty common for the regulator IC to go bad. Its inside on the power supply Printed circuit boad assy. It will start with STR#### and have 4 digits after the STR####, depending on the model of the set. Good Luck
Jun 03, 2006 | Toshiba 51H93 51" Rear Projection HDTV
Toshiba 51H93 51" Rear Projection HDTV Logo
180 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
