Question about GE APN10AA Portable Air Conditioner
I have an APE08AJM1 GE Portable A/C that the compressor doesn't cycle off and on when it reaches the preset temperature on the panel.
  • 334 Answers
Either the temp sensor is dirty or bad, or the thermostat is malfunctioning.
Clean the sensor first.
If it does not fix the problem.......
While turning the t-stat all the way up and all the way down, listen for a click. If there is no click, replace the t-stat. If there is a click and the compressor still does not shut off, the relay is stuck and should be replaced.
Posted on Jan 31, 2010
  • Tony Jun 30, 2013
    Where is temp sensor located on unit so I can clean it?
Do i need to gas up my unit
Posted on Jul 10, 2011
I ve never used this AC an need 2 know where 2 put yhr water in at 2 get cold air
Posted on Jul 16, 2010
APE08AJM1 - GE 115 Volt Portable Electronic Room Air Conditioner - Compressor not kicking on. Manual indicates it's triggering the overload relay? How do I solve this?
There is a start capacitor near the compressor that may be bad. If the capacitor tests OK then the compressor is locked up. A service man can try to get it going with a kicker capacitor but there is no guarantee that that will work.
Sep 14, 2017 | GE Heating & Cooling
GE dryer runs but only heats on timed cycle not the other 2 cycles.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Feb 17, 2015 | GE Dryers
Why my 95 wrangler does not leak freon but the ac comes in and out
the ac compressor will cycle as the thermostat setting is reached
as the temperature in the cabin reaches the set temperature or climate control temperature then the compressor will cycle on and off.
May 31, 2014 | Crown Jeep Wrangler yj 95 94 93 92 91 90...
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
Duo-Therm ac when the temerture is reached the fan will shut off but the compressor stays running
Sounds like you hit it on the head--compressor should turn off when unit reaches the preset temperature.
Jun 10, 2012 | Dometic Rooftop RV Air Conditioner
Does the GE APE08AJM1 air conditioner come with a dehumiderfer on it?
Yes, the unit has a 4 pint per hour dehumidifier as one of it's features.
More information on this model portable AC unit and a look at & print it's Owner's Manual, click on the following link. http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=APN10AA
I hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | GE APN10AA Portable Air Conditioner
Ac clutch kicks on and off, is there a thermal coupler?
There is a temperature control in an AC system and the compressor kicks out when the selected temperature is reached in the vehicle, it kicks on again to maintain the preset temperature.. There is also a pressure switch in the system that cuts out the compressor if the gas/lubricant in the AC is low and continued use of the compressor may damage the component.
Jul 10, 2011 | Ford Tempo Cars & Trucks
My GE Refrigerator model GSL25JTFBBS stay in
Good day,
35 minutes would be considered nominal. That is the amount of time needed to heat up the cooling coils behind the rear panel in the freezer compartment, and then allow it to drain the condensate water out the drain.
The defrost cycle is made up of 2 parts.
The first part involves shutting all fans and compressor off, and turning on the heater/heaters mounted on the bottom of the cooling coil to above freezing. About 10 to 15 minutes.
The second half occures when a defrost thermostat mounted on the top of that coil senses the coil is above freezing. It cuts the power to the heaters, and lets the system just idle, while the water is allowed to drain out of the drain.
If that tstat is working properly, the food temperature is affected slightly but never to an above freezing condition.
The thermostat is a small 1" round disk clipped to the top of the coil.
Only one possibility, but that tstat could be hanging allowing the freezer coil compartment to reach a very high temperature. If so, it needs replaced.
You should also check to see if both fans and compressor start running as soon as the cycle is done.
Mar 12, 2010 | GE CleanSteel GSL25JFTBS
E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Sep 26, 2008 | GE APN10AA Portable Air Conditioner
GE APN10AA Portable Air Conditioner Logo
900 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
