Question about Sony RMT-V501 Remote Control
MY SONY RMT-V501 REMOTE WON'T WORK EVEN AFTER I CHANGED THE BATTERIES
5 Suggested Answers
fps353535
  • 99 Answers
SOURCE: programming
Here is the sony support site. i tracked down the manual section on the site, this is it
NOTE you must enter your TV Model to obtain the programming code
http://esupport.sony.com/CA/perl/model-remote.pl?mdl=RMTV501
Posted on Apr 12, 2009
  • 403 Answers
SOURCE: my remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
  • 524 Answers
SOURCE: I have a sanyo universal remote and toshiba tv.
hi
Sometimes code wil not be accepted.
Please try same procedure with these codes
120
121
130
131
Thanx
Posted on Jul 21, 2010
ercupa190
  • 12223 Answers
SOURCE: SONY RMT-D222P - CHANNEL UP BUTTON
Try to clean contact with contact cleaner spray( radio schack or computer sotre.
If the problem persist Reset with you code in your manual if you do not have the code go to: esupport.sony.com and download free.
After that if the probllem remain, your contact in the remote control is faulty.
Replace it.
Good luck, G-d bless you
Ernesto Cuadra
managua,nicaragua. c.a.
Posted on Dec 13, 2011
How do I program my rmt-d301 to work with my Sharp TV?
HI,
Check the bellow link to know about the procedure for using Sony RMT D 301 remote with Sharp TV
Sony RMT- D 301
Mar 14, 2013 | Sony Remote Control RMT-D301 p/n:148907111
Sony RMT-D187A stopped working!
1= change the batteries by new ones
2= clean the contacts cleaners with contacts cleaner
3= resolder the wires contacts batteries
4= retight the spring contacts batteries with pliers for better contacts
5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts.
6= try agan, if doesnot work go to the repair shop TV for fix it.
God bless you
Jul 19, 2012 | Sony Televison & Video
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Jan 08, 2012 | RCA DIRECTV Satellite Remote Control
SONY DVD REMOYTE RMT-187P NOT RESPONDING EVEN AFTER CHANGING THE BATTERY
The remote might be bad or the sensor on the remote or the television is bad. If the metal that holds the sensor light on the remote or the television becomes rusty and breaks off, the remote will not be able to operate the television anymore.
Check the remote and the televisions remote sensor if it is still okay. If they are both okay, then it means the remote is dead and need to be replaced.
Thank you for using fixya.
Caseytech
Sep 05, 2011 | Televison & Video
I do not know the steps to take to program my Sony Video (RMT-V306) remote to my Toshiba television.
To program your Sony RMT-V306 remote:
  1. Set TV_VIDEO switch to TV
  2. Turn on television to be programed
  3. Press & hold the I/O (Power) button
  4. Enter TV code (Toshiba = 07)
  5. Release I/O button
  6. Press I/O to turn off TV
If you have a different brand TV, you can get the code from Sony's e-support site here.
  • Remember, when changing batteries you will need to reprogram remote.
  • The RMT-V306 will not control all functions of your component.
  • Although not common, there may be some components the RMT-V306 cannot control.
Dec 22, 2010 | Sony RMT-V306 Remote Control
Remote RMT-D240A not working with RDR-VX525 DVD Player that it came with. Only get DVD Screen saying DVD 3, will not even turn ON/OFF.
You may have to reset the remote to the current command code. Here is the link for how to do that. http://community.sony.com/t5/Remote-Controls/RDR-VX525-Changed-to-DVD3-on-command-control-and-remote-won-t/td-p/158777
Dec 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
RMT-V402B Remote Control: i can't seem to get the menu to come up, i have ch...
The remote is universal and is not compatible with all functions of unit.
May 07, 2010 | Sony RMT-V402B Remote Control
Just bought a used Sony Trinitron - need to adjust audio/visual
You can purchase in most cases at Kmart, Walmart or places like that universal Sony remotes which should allow you access to those features.
Oct 17, 2009 | Televison & Video
Sony RMT-V402A VCR Remote Suddenly Stopped Working.
The batteries may be defective or installed incorrectly. It is not unusual for a remote control to suffer spontaneous complete failure.
Nov 28, 2017 | Sony Televison & Video
Programming
Apr 12, 2009 | Sony RMT-V501 Remote Control
Televison & Video Logo
172 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
