Question about Philips GoGear HDD1830 MP3 Player
Cant get my comp to reconize the Philips GoGear HDD1830
When i plug in the usb port to the back of my comp nothin happens
  • lewlew Feb 18, 2008
    ok i downloaded all the SF from the website now it is sayin that my player is not connected. i turned off the mp3 player and unplugged it from the port then turned it back on and plugged it back in and still nothin
    Genius:
  • 1,665 Answers
I have the philips go gear hdd1830 and it wont turn on. I tried to connect it to my computer and it does not show that it is connected to the computer and no charge as well.
Hi it sounds like the onboard battery is flat, so will not swich on. You have also stated the player is not recognized by the PC and not charging.
Try another USB lead and also try another USB port, either of these could be at fault.
Apr 17, 2010 | Philips GoGear HDD1830 MP3 Player
I went to trun my friends Philips GoGear HDD 1830 mp3 player on and it just froze, is there away I can fix it with out loseing any song's, pic's and other stuff that is already on there? please help......
try plugging it into a charger or usb port. this usually causes them to reset. unless there is a serious problem with the memory you should have to worry about lost data
Mar 08, 2010 | Philips GoGear HDD1830 MP3 Player
My philips gogear 8 GB media player won't take a charge or nothin
Uninstall the MTP Device by going to Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> Device Manager - should stop the connect/disconnect issue.
Jan 06, 2009 | Philips GoGear SA3125/37 MP3 Player
I had the same problem. Nothing wrong with usb you just need a .2 ampere charge. PC USB is not enough. I got an external adaptor and works fine.
Jan 06, 2009 | Philips GoGear HDD1830 MP3 Player
I don' t know how to insert pictures in Philips GoGear HDD1830 MP3 Player
You must install the CD that came with the player. It contains a critical plug-in that is necessary for picture viewing.
Nov 15, 2008 | Philips GoGear HDD1830 MP3 Player
Usb cord
Plug the Mp3 player to a diffrent USB Port and reboot the computer it should work
Aug 04, 2008 | Philips GoGear HDD1830 MP3 Player
Gogear 8gb
The HDD1830 is not Mac compatible. The database file has probably been deleted or corrupted. The player doesn't scan the hard disk on start-up, it only read the database file. Anything it doesn't read from the database file is ignored.
You will need to restore the player with the Philips Device Manager, and re-load your tracks.
Jun 20, 2008 | Philips GoGear HDD1830 MP3 Player
Philips gogear micro jukebox hdd1830/17
If your car radio has a 3.5mm jack socket input, then you only need a 3.5mm jack to jack lead.
If your radio is a cassette unit, then you can buy a cassette adaptor that plugs into the headphone socket.
Failing that, check the radio's manual, as some have an input in the back.
Apr 17, 2008 | Philips GoGear HDD1830 MP3 Player
Cant connect to usb port
the connection to your gogear will be smaller than the usb to your pc, it's the same with all peripherals, you should have been supplied a cable with it, standard usb one end and a thinner or squarer conection at the player, see below for examples http://www.directusbstore.com/cnb/shop/directusbstore?op=catalogue-products-null&prodCategoryID=55
Sep 13, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
59 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
