Question about Jandy Ray Vac Pool Cleaner for Inground Concrete
My Ray Vac is also floating in a nose dive position. I ajusted flow valve, speed,cleaned filters and nothing works Please help
  • frevi Jan 31, 2010
    That's not the problem . I took the head apart and there's no cracks inside
  • 990 Answers
You have a head float inside the head that has probally cracked and filled with water. You can take this apart yourself or your pool store will probally do this for you for just the price of the part. Then they can look over the whole thing for you. Just remove the head and bring it into the store. Good luck.
Posted on Jan 31, 2010
  • Kieran Ruppert Jan 31, 2010
    You probally won't see any cracks but if you pull the float and shake it can you hear any water. If that's not it I'm lost without more info.
Why is gas flow out of tank good until connected to carb?
could be the float in carb is stuck shut . they have to breathe also you know .
Nov 20, 2015 | ATVs
How to check the water flow valve
the valve lets you adjust the flow through the vac. start with it in middle position. if the unit is sluggish, you need to increase the flow by closing the opening. make sure that there is nothing caught in the unit. sometimes eating toys is more fun than cleaning a pool
May 23, 2014 | Zodiac Pacer Pool Cleaner
I have a 1986 suzuki 650 savage the carb seems to have a problem. It started flooding gas coming out the over flow. I took it off and took the float cover off and replaced the needle needle set and float....
Yea these carbs can be a real pain sometimes to get right. First thing you need to do is varify the float seat is working and totally stopping all fuel flow.... and all the jets, main, pilot and choke circuit are absolutely clean. Bench test the float needle valve by connecting a hose to the carb fuel line nipple and letting gas gravity feed as it would in a run position. if it tests ok, remount it on the bike...
i'm guessing you have a vacuum petcock on this year model? If you do, it needs to be inspected.
In the "on" position you should have no gas flow coming through the petcock, In the "prime" position it free flows. If there is a hole in the diaphram the engine will **** gas and not air (vacuum) through the hose and it will flood. If you don't have a vacuum line on your petcock then it is a different kind. Be sure to check your crankcase, it could be way past full with gas that has entered, dont start your engine like that...drain it all out. make sure the air filter is dry. You will have to replace the spark plugs...a gas soaked plug won't fire.
Good luck, i hope this helps.
Jul 16, 2011 | 1986 Suzuki LS 650 Savage
My 2006 klx 250 won't fire, no fuel in float bowl, Tank is full, I drained the float bowl to try to get it to start and now no fuel is getting to the bowl
Check the filter screen on the fuel tap for blockage etc. Also check the tap for anything that may have lodged in it and blocking it. Check the fuel pipe too.
Mar 09, 2011 | 2006 kawasaki KLX 250
Water is not flowing into Bosch diswasher
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 21, 2011 | Dishwashers
My Poulan 2005 17.5 HP, 42" mower runs a few minutes, then sputters and either almost dies, or does die. If it doesn't die, it will speed back up and I can mow 20 or 30 feet and it will sputter again, and...
I hope this helps as quickly as it helped me. Try cleaning the small vent hole in the gas cap. I had asked Fixya this question last year and it worked like a charm! Good luck.
Sep 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I need to clean carburetor on 340gx honda pressure washer. How would I do this?
pour large amounts of liquid carb cleaner into the gas tank
Let it run for a couple of minutes then shut it off and let it sit for a couple of days.
Aug 16, 2010 | Honda Garden
Polaris 380 stand on nose while on will not move to wheels on ground what could be the problem
First, check to confirm that the blue restrictor disk is installed in the UWF to decrease water flow. It sounds like you are getting too much water pressure. You could also install the red restrictor disk to decrease water flow even more. If this does not work, verify the back-up valve is cycling. Hold the valve out of the water and watch the jet. It should come on and go off. Make sure that your thrust jets are working properly and are positioned correctly. Also, try removing the head float and shaking it. If there is water in the float, you will want to get a new one. Finally, check the hose floats to make sure they are
spaced evenly. One of these soultions should make your pool cleaner function properly. If you need additional help, please let me know.
May 17, 2010 | Polaris 380 In Ground Pool Cleaner
HOW TO GET INLEET VALVES SET PROPERLY WITH VAC
Here is a copy of the Jandy Users Manual for the model of pool filter that you own. It has a diagram of all the working parts of the filter and should have all of the information that you need. Please let me know if this does not answer your question.
http://www.backyardcitypools.com/images/jandy/CL-series-manual.pdf
Sep 17, 2009 | Jandy Series Cl460 Filter Cartridge, 115...
Jandy Ray Vac Pool Cleaner for Inground Concrete Logo
113 people viewed this question
Top Jandy Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jandy Garden Expert? Answer questions, earn points and help others
