When I connect component cables to my 52" rca it shows 3 pictures, why is this?
  • 8,617 Answers
Rca Tvs have to have each format adjusted if not one format will be fine and other formatts will have convergence issues as you describe.
Posted on Jan 31, 2010
We have a RCA D52w19 rear projection tv. It appears that the HD feature is not working. My Wii does not recognize it as HD and the picture for Wii, satellite and DVD is noticeably grainy. Is there an easy...
The Wii is not a HD output source. It only displays 480p. If you wish to connect an HD source, you must connect through an HDMI cable or a component Cable. HDMI is better.
Feb 28, 2011 | RCA D52W19 52" Rear Projection Television
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. Sparco.com had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
The picture shows all 3 colors seperate from each
Sounds like a problem in your convergence circuit. This is the circuit responsible for making sure all 3 colors align perfectly so that you don't see what you are seeing now. If you have tried adjusting it and that did not work then you will need to have the convergence circuit repaired.
May 24, 2010 | RCA R52WM24 52" HDTV Projection Television
60" RCA TV
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
Apr 02, 2010 | RCA P52921 52" Rear Projection Television
HOW CAN I GET THE HD PICTURE CLEARER?
Hi there.
To answer your question;
Since you said that you can`t use hdmi/dvi your next best choice would be component video input(3 rca cables).
Your next choice would be svideo in.
It may improve your picture over standard cable in.
hope this help. Happy holiday
Dec 28, 2009 | RCA HD52W58 52" TV
I get a color picture when i hook up the WII(FRONT) but not when i hook it up to a converter box(in the back) to watch basic TV. Is there another type of connection i need. Unfortunately i don't have...
What color jacks are you connecting your box to. Sounds like you are connecting 3 wire video or component connection incorrectly. Green,Blue,Red wires require same on both ends. If not correctly connected you will get the picture you are describing. The yellow wire composite video requires only one wire. I see this all the time . Some one has connected the yellow wire out the the green component in.The componet video takes 3 wires for video and 2 for sound five all together. the composite video yellow wire takes 1 video and 2 audio wires. Can't mix them together they are different. Hope this helps you.
Dec 18, 2009 | RCA D52W23 52" HDTV CRT TV
Mitsubitishi TV model VS50800 (1998) - sound but no picture. What could the problem be, defective 'bulb'?
There may be a switch on the back of the TV that chooses whether to output video to the component connections or the RCA/S-Video connections.
RCA cables - red, yellow, white
S-Video - single cord (usually black)
Component Video Cables - red, green, blue
Sep 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No sound
Is the DVD player connected to the TV via component cables? If so you should have 5 connectors total that will bring picture and audio information to the TV.
Jun 22, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W15 52 in. Rear Projection HDTV-Ready Television
The component connections are usually video only and the audio goes to separate connectors set aside for that input. Check your manual to make sure you have all the connections made.
Dec 02, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
