Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
Need to download manual fo mag 77 saw - Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
    President:
  • 2,992 Answers
Manuals can be downloaded from Skil here. Click the down arrow next to "New Products", then choose "Corded Circular Saws" and you'll find several model 77s listed. Pick your specific model and there you go.
Hope this helps! Thanks for using Fixya.
Posted on Jan 31, 2010
I need to know what kind of oil do I use to change the oil in my skill saw 77? Mine is pretty dirty, runs great but thought I should change the oil. Thanks Bill
Use Skil worm drive oil #80111 ($5-$6.00) at Home depot, or Bosch WD7LUB 2.3 FL. OZ. (I bought for $3.50 at Bosch service center.)
Aug 28, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Describe your How do u put a trigger an a mag 77 skill saw Problem
There are a few screws on the handle, remove them and it comes apart in 2 pieces, the trigger assembly will then come out. Disconnect the trigger from the wires and replace. Any Bosch service depot should keep this part in stock.
Cheers,
Kevin
Mar 23, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Depth of cut lever very tight.
This unit has a lock nut on the cam actuation of the height adjustment. Loosen the locknut a touch at a time to get the right feel you are lookin for.
Jan 15, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How much lubricant do I need to replace all of the lubricant in my old skil 77 7 and 1/4 " saw?
Put saw on level surface than fill till you see the oil come up to the threads. Do not let it hit the threads or it is over full.
Jan 11, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Nov 17, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Describe your Skil 7 1/4" Magnesium
You have large plastic screw on the saw, remove it and fill the oil to bottom of threads and that should be it.
Sep 15, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Switch burn out
Home Depot sells a replacement switch for the mag 77
Oct 09, 2008 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Manual for Skil Saw model 77 type 17
I have a Skilsaw model 77 type 16. I have the original owners manual and would be willing to fax you a copy.
The manual only lists a part number for the gear oil, it is No. 249. This is for a 5-3/8 oz tube of gear oil. I checked with my local hardware store which services this saw and they called a factory rep. They told the hardware store with shipping and handling it would cost about $17 for the oil! However they also said that a 90 weight gear oil is close enough to solve the problem.
Hope this helps.
Sep 22, 2008 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
215 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
