Question about Vacuums
I have any easy-flo built-in vacuum. I recently had the bearings on the motor, top and bottom replaced. I put the vacuum back together and it mow has low suction power. There is plenty of suction on the side of the canister where the rigid tubing meets the canister body but little suction at the wall plates. Any ideas? Roger
  • roggercole Feb 20, 2008
    Thank you. With your help, I have determined that there is probably a blockage somewhere between the main floor and the upper floor of the house. Any idea how to clear it?
  • 126 Answers
There is either a blockage or a pipe is open somewhere. You should check the system at the wall valve without the hose to determine if the pipes are blocked or if perhaps the hose is plugged. If one of the wall valves is damaged or open, this will affect the whole system. Some times, there is painting or renovations taking place in the home and a valve has been removed during the work. I have seen this many times. All valves must be in place and closed for the system to function properly. I have also seen garage valves held open by storage boxes, etc. and they are overlooked because they don't get used often and in some cases, the home owner doesn't even know they are there.
If you turn the machine on with the switch on the side of the unit, observe the sound of the machine. If the motor races, then the pipes are closed (no breaks). If the motor runs normally, you have an opening somewhere. The same thing applies to the valves. If you turn the machine on and the motor races even when a valve is opened, then you have a blockage, but if the motor doesn't change when a valve is opened, then the pipes are compromised.
I hope this helps. Let me know.
Posted on Feb 18, 2008
  • Ray Sabourin Feb 20, 2008
    The first thing to try is to attempt to remove the blockage with another vacuum. Get another canister vac. A shop vac or something with lots of suction. Take the bucket off your easy flo. Go to the valve nearest the blockage and insert the hose into the valve making sure that you get as tight a seal as possible. Make sure that the portable vac is clean and is making all the suction it can. Turn it on and see if it will suck the blockage back. What will probably happen is that it will pull part of the blockage up to the valve and you will have to remove the hose and clear the debris from the back of the valve. Re-insert the hose and go again. You might have to do this several times. The reason you take the bucket off your easy flo is so that air can pass back up the system unobstructed. The bucket will add resistance. Sort of like sucking on a soda bottle. If this does not help, you will have to get an electricians "fish-tape" and feed it down through the valve and work the blockage loose by pulling on it and breaking it up. I often use a combination of these two methods on a stubborn blockage. DO NOT USE A PLUMBER'S SNAKE. They can damage the pipe and even break it.
    Once you get it cleared, take a couple of squares of toilet tissue or a kleenex and let it go through the system. Go check the bucket and see if it came through. If it did, then you pretty much got the blockage and should be o.k.
    Good luck. I hope this helps.
Replacement motor bearings for a genie shop vac/blower model# pb 15
Unfortunately those machines do not have serviceable bearings. The entire motor needs replaced. However, I have saved noisy bearings by putting oil on them, specifically 3 in 1 Blue Label motor oil. A few drops spread on the top and bottom of the bearings and giving the motor a few backward and forwards turns by hand will help those bearings immensely.
Feb 20, 2016 | Genie Company Vacuums
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
Our Easy-Flo built in vacuum system will not turn off, even when the hose is disconnected. We have to turn it off manually. Could it be a short in one of the wall outlets causing this?
Some models have an on/off switch on the power unit itself. This switch is used to turn your power unit on when you are right at the machine.
If there is no switch on the power unit, unplug your power unit from the wall socket, look for two low voltage wires coming out of the power unit. These two low voltage wires are usually either attached with terminals or are tied to two wires coming out with plastic screw on wire caps. Disconnect the 2 low voltage wires. Plug your power unit back in. If the power unit does not come back on then yes, the problem is most likely a short in the outlet wiring. If the power unit still comes on with the 2 low voltage wires unattached, then the problem is in the internal circuitry of the power unit, usually a relay or some units have a circuit board with relay, circuit breaker and other components on it. The relay or circuit board will have to be replaced.
It's a little difficult to check for a short if you have multiple outlets, but if you've recently done some renovations you might start checking in that area.
May 19, 2010 | Easy Flo EF1400 Central System Vacuum
My easy flo built in system wont turn on when the
If there is a switch on your hose, it may be broken.
Your system powers on from the inlets via two low voltage wires that run from the inlets to the switch/relay at the power unit. Each inlet has 2 spring loaded pins attached to the low voltage wires. In the photo below you should see these pins at the bottom of the opening, just above the door hinge. The receptacle at the top of the inlet in this photo supplies 110 volts to power your power nozzle. Not all inlets have this option, but if yours does, exercise extreme caution. Your hose must have a completely metal end or if it is a plastic end, it must have a metal band in order to short the 2 low voltage wires together to trigger the switch.
You can manually short the two low voltage pins together by using a metal pipe or needle nose pliers, just touch both pins at the same time. CAUTION: stay away from the 110 volt receptacle if present.
If your system powers on with this manual method then it would seem that the problem is in your hose.
If your system does not power on; your low voltage wires may be disconnected from the power unit or disconnected somewhere else . It's also possible that you have a bad circuit/controller board in the power unit.
May 11, 2010 | Easy Flo EF1400 Central System Vacuum
I have an easy flo vacuum model # 199C and it won't shut off. It started out as an intermitent problem but now will not shut off when the hose is unplugged, nor when the off/on switch on the main unit is...
Remove the low voltage wires (top left) if the vac unit still runs the problem is with vacuum
if the Vac stops running then there is problem with the low voltage wires in the home possible short some where in the system Chech the inlet doors first. Easy Flo vacuums have a lifetime warranty call 1800 easy Flo.
Feb 13, 2010 | Easy Flo EF1500 Vacuum
How to clean turbo brush of harmony electrolux and put it back together properly
Wait, there are two more screws that must be removed before the top shell will come off. They are located under the wheels. Pop the wheels out by simply inserting yoru finger or a small tool into the wheel and pulling straight up. Remove those two screws and then you can proceed as mentioned above.
When reassembling the head, if the shell does not snap back onto the base, check for plastic chips or other debris in the narrow slots on the underside of the shell. Clear these slots out and the head should easily snap back together.
Dec 02, 2009 | Electrolux Harmony Canister Vacuum -...
Easy-Flo 1525 will not turn off
There is a relay back on the master unit. When the hose is plugged into the inlet the metal on the coupling completes the electrical circuit to the relay. In your case the coupling has a split and the circuit continues to the switch in the handle. As long as there isn't any conductive surface left across any of the contacts in any of the inlets, the relay is hung up. I never heard of that happening until today when I responded to the exact same problem on a different machine. The relay needs to be replaced.
The "screeching" on the other hand should have nothing to do with the relay. That sounds like a motor bearing without proper lubication and/or going bad.
May 22, 2009 | Easy Flo EF1400 Central System Vacuum
Rainbow se trying to fix
small red washer on top - motor is the top. Also on only everyother fan spins.
Small fan with the small hole up
Barrel Spacer
Large Fan with the the hole down
Hour Glass spacer - this spacer has a washer welded to the bottom of it - spacer down!
small fan hold down.
Lower motor housing
Hope you changed the bearing while you were where here.
Give it a spin by hand and make sure there is no grinding.
Hope this is right, doing it from memory, have a picture at work.
Good luck
M
Sep 23, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Savvy vacuum belt
It is easier when you also take the top off. Then you can put the belt over the roller and re-install it, then put the bottom plate back on, then turn it over, undo the motor and put the belt on the motor pulley, re-install the motor and put the rest back together. To remove the top, thewre are a couple of scres from the bottom, then from the top, remove the Hoover emblem, there is a screw there to remove and the top will come off.
Jul 11, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
99 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
