Question about Electronic Arts Medal of Honor: Pacific Assault for Windows
Pressed a key by mistake and now guns don't fire
  • 3 Answers
You might want to check the options menu and see if you changed your primary fire to another key if not ask EA games LOL!
Posted on May 05, 2010
    Problem Solver:
  • 3 Answers
Maybe it tilt hehe
Posted on Jan 31, 2010
My NT65AB is double firing every 4th to 8th fire, is there an adjustment on the trigger?
Chris, you will have to check your manual to see if your make and model has adjustment. Double fire is normally caused by one of three things,
1. The nailer is not being held down with enough pressure when the gun is fired.
2. Triggers valve is leaking and not releasing fast enough for a single shot.
3. The pressure fire feature on the nose of the gun (if applicable) is faulty.
If adding pressure does not help, then it is most likely faulty trigger, replace it. For guns that use a press-and-fire system, the spring in the nose of the gun may be worn, causing the double fire of nails.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Diagnose Power Air Nailers
nailer double nailing
http://www.mastertoolrepair.com/images/How%20to%20Repair%20you%20Nailer.pdf
May 23, 2016 | Air Tools & Compressors
I USED FULL HEAD NAILS BY MISTAKE, NAILER STOPPED FIRING AFTER USING QUITE A FEW NAILS IN IT. WHAT DO I NEED TO DO?
Did you try to disassemble the nose? Sometimes the firing pin gets stuck in the down position. Small bits of metal from the nails may seize it up periodically, especially if it was trying to push out full-head nails.
Make sure the gun is not under pressure, and when you take it apart to inspect it, add oil wherever you can to help get things moving again. Even if a gun is oil-free it's not gonna hurt it.
Hope that helps - I have mainly Bostitch nailers, and similar scenarios have happened to me with a few of my guns.
Nov 21, 2015 | Dewalt d51825 hd 31deg clipped head...
I have a paslode model IM250II 16 ga straight finish nailer that I bought used the gun fan and motor runs whin the trigger is pulled but it does not fire when the tip is pressed no pop no puff nothing I...
Fan running when trigger pressed is normal however to make it fire you need to press on the work probe first and the fan should start running, at this point the gas should be injected and pressing the trigger should create the spark to fire the gun, if all works as above but the gun won't fire check the gas, the metering valve on the can should have a yellow ring and when pressing the can nozzle on a hard surface, gas should be released, if not the can either has (a) insufficient gas, (b) the nozzle is not correctly fitted (c) the metering valve is faulty, if the can emits gas the gun will need to be checked for spark and the seals will need checking
Aug 21, 2013 | Tools & Hardware - Others
Nail gun has stopped firing nails
make sure that the nails are loaded in straight and packed down tight
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Why does my Hitachi nv45ab gun double fire nails?
This gun should be bump-fired only. Do not place the gun on the work and press trigger. Make sure that the safety spring is in place and has good tension. The spring helps to push the foot off the trigger so that it fires once. You could also adjust the screw that pushes on the firing valve. Turn in or out several turns till head of nail is correct when bump firing then lock the nut. The safety foot fits rather loose on the gun and should still work ok but can get so loose that it falls off the nose. Good luck
Jan 23, 2013 | Hitachi Air Tools & Compressors
GUN DOES NOT FIRE FOR SEVERAL ATTEMPTS--even though gun is pressed firm against work---just had unit serviced and trigger valve replaced-----any suggestions? thanks joel
Remove nails and remove trigger to expose trigger valve pin. Place nose of gun against rubber pad or old coiled up air hose to absorb impact of driver and with very quick and deliberate motion press in trigger pin. If gun fires, then problem is with safety foot not pushing trigger pin all the way in (or worn trigger). Make adjustment as needed or replace faulty parts. If gun still does not fire, then likely problem is with headvalve. If headvalve orings are leaking, gun will not fire. Test for leaking orings as follows. Remove head and remove headvalve, apply silicone paste lube (plenty) to all orings and where orings contact. Assemble and do test above. If gun fires then surface where orings contact is allowing air to leak(smooth with very fine sandpaper if scratched).
Mar 13, 2011 | Stanley Piston Driver Assy Bostitch N60fn...
I have rebuilt my staple gun all new seals new piston and driver blade new bumper cushen when gun shoots the blade wont retract up all the way you have to open the staple mag. fire the gun then the blade...
Inside the cap, there's a plastic circular insert. It's a common mistake to reassemble the gun with this cap spacer upside down, resulting in the top of the cylinder not sealing in the air that returns the piston. Simply undo the cap, turn the spacer over and screw it back on again. Done.
Feb 27, 2011 | Fasco Tools & Hardware - Others
Electronic Arts Medal of Honor: Pacific Assault for Windows Logo
199 people viewed this question
Top Electronic Arts Video Game Consoles & Games Experts
akigawa
Level 1 Expert
James Wishart
Tom Chichester
Are you an Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
