Question about Aprilaire 700 Humidifier
The water will not stop flowing even with the unit off.Model 700
  • Aprilaire Master
  • 2,600 Answers
Hi check the power to the transformer then power to the water valve , valve could be stuck in the open postion
Posted on Feb 02, 2010
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Aprilaire 700 draining water even when blower is off
Hello, if the blower is off and the water keeps flowing most likely the solenoid valve is bad and must be replaced.
Oct 24, 2011 | Aprilaire 700 Humidifier
Water keeps flowing through my humidifier even when the furnace is not on. Consequently my water bill is quite high. How do I take care of this problem of the water continuously flowing through the unit?
There should be a solinoid valve that starts and stops the flow of the water, based upon a call for heat, and to ensure the fan is running during operation. There must be some failure with this valve, or a short in the connection causing it to run constantly. Hope this helps
Mar 19, 2010 | Humidifiers
Aprilair 760 Humidfier will not stop water flow to EV panel
If the water continues runs nonstop even when the heater is turned off, you might have either a bad solenoid valve or a bad humidistat. Simply disconnect one of the two low voltage wires going into the unit. If the water turns off then your problem is most likely your humidistat or the low voltage wiring. If the water continues to run even when the low voltage is disconnected you have a defective solenoid valve.
Good luck.......
Apr 09, 2009 | Aprilaire 700 Humidifier
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
Fan running but no water flow
the humidistat on this unit just acts as a set of dry contacts. with the humidifier plugged in, you should be able to touch the 2 brown wires by the water solenoid together and get the power fan to run and the water solenoid to enrgize. if you do this and water does not flow, you most likely have a bad water soenoid. it is either electrically bad, or just plugged with water deposits. sometimes you can pull it apart and clean it, sometimes you just have to replace the solenoid.
Jan 26, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 humidifier not adding any humidity
Thanks for your Question,
Sounds to me like you have a calcium build up in the Solenoid, which is restricting flow to the unit for proper operation, you might even have a bit of restriction in the copper line feeding the Solenoid, replacement of the solenoid would probably take care of your problem, one quick tip, in the spring and summer months, its a good idea to shut the water off to the unit, this should make the Solenoid last a little longer, hope this was helpful to ya, please let me know, thanks again,
mr.grzz
Jan 12, 2009 | Aprilaire 700 Humidifier
What should my humidifier be set at for the winter?
Hi, Jennifer:
I'm no expert, but those who are seem to agree that the first thing to check is your evaporator panel. Aprilaire recommends replacing it annually--so if you haven't replaced it recently, that would be the first step to take. Next, check the power supply to your Aprilaire unit. Turn the humidistat to 0%, and then turn it slowly back toward 35% until you hear a click at the unit. If you don't hear a click, you'll want to check that the unit is in fact getting electric power (you may want to get an electrician or furnace tech to do this). If you do hear the click, the next thing to check is whether you have sufficient water flow to your Aprilaire unit. On mine, I had to adjust my water supply saddle valve, as well as the inline valve on the discharge side of the solenoid (see prior post from this morning)--and this seemed to clear the lines and restore water flow. Once you achieve proper water flow, you will probably want to set your humidistat at 35% for winter temps of around 20 degrees F--but be sure to adjust it downward for colder weather. Comments, anyone?
Dec 13, 2008 | Aprilaire 700 Humidifier
Humdifier on furnace
I have the exact same problem. At this time I am looking for a new solinoid (part on the bottom) to install. Anyone else having this problem and know where to find replacement parts
Jan 22, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
