Question about Ecoquest Fresh Air Living Air Purifier
I replaced the plate but the display still says "replace plate".
  • 3 Answers
Try to press "Reminder Reset" on front of unit.
Posted on Feb 18, 2010
Fresh air yd-700a e001 error
My unit would display e001 and e003 errors. Cleaning the filter and replacing the ceramic ozone plate did not fix it. Ended up taking the board out and inspecting it. Three capacitors were bad. After replacing, the system is working again.
Nov 01, 2013 | Ecoquest Fresh Air Air Purifier
Fresh Air: Replace the plate
I found this link to get parts for it:
airpurifierrepair.com
Ecoquest can support the product for you as well regardless of who you bought it from.
Oct 06, 2008 | Ecoquest Fresh Air Air Purifier
How long do Ecoquest purifier plates last?
The "Replace Plate" message comes on for more than just the plate. Is the fan still running when it displays (Replace Plate"? The squeaking noise would be coming from the fan. I don't know what all it works for. It does display when the plate contacts are dirty, when a wire to the plates is loose or corroded, when the bulb is bad or loose and when the ozone generator quits. I have encountered all of those. Plates should last a couple of years, depending what's going on in the indoor environment. Before you go any farther, call (336) 499-2505 - they give away information and will help you solve your specific problem.
Jun 11, 2012 | Ecoquest Fresh Air Air Purifier
One of my plates has a loose wire and it's making a noise when its on. Can I replace the plates. Also I have misplaced my cord. Thanks
You MUST replace the plate!!! Do not use any damaged plates in the machine.
You can order the plates and a new cord from the company. Vollara (new name for EcoQuest) customer service is 800-989-2299. Use #16618 if you need a referral number.
Although the company is no longer selling or servicing the Breeze, the plates and cord are standard components which are also used in other products still manufactured by the company.
Hope this helps.
Jan 14, 2011 | Ecoquest Breeze AT Living Air Purifier
I have 2 Ecoquest Fresh Air purifiers located in oposite ends of my basement. One in my work shop area (approx 28x32) and the other in my finished basement area (approx 28x50). The reason I chose this...
Hi Ed,
You should also clean the contacts points that touch the plates with the amonia and water solution. Use a brush and to remove any deposits on those contacts. Also the purification plates will not work if they are still damp when they are put into the machine. They must be completely dry in order to work. Use a hair dryer to dry off any water on the metal grid or allow them to dry for 24 hours. Hopefully that should get your plates going again.
In regards to when you should replace the plates. As long has the plate material is not cracked and you can clean the metal grids to a shine they should be good. But they should be able to last several years with good maintenance.
The RCI cells should be replaced every 3 years or when the machine displays "Replace RCI" message.
Hope this helps you.
Dec 04, 2010 | Ecoquest Fresh Air Air Purifier
Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Jun 03, 2009 | Ecoquest Fresh Air Air Purifier
Plate error
the metal contactors and the wire spade connectors get pretty corroded and can cause continuity problems .i have had to replace those spade connectors and clean the metal contactors with emry sand cloth.another trick is to soak the plate in ammonia to reduce the corrosion present on the grids
Apr 08, 2009 | Ecoquest Fresh Air Air Purifier
Message says Replace Plate
Pat,
the circuit board might be the issue here. There is another possibility.
Sometimes the contacts that connect to the place do not make good contact. You can try to carefully bend the contacts after removing the plate to create a tighter fit. Be careful not to move/force the little bar where the contacts are connected to.
Cleaning the contacts with denaturalized alcohol might work too.
Hope this helps!
Eric
Dec 10, 2008 | Ecoquest Fresh Air Air Purifier
BULB AND LAMP
I can give you some possibilities. A loose connection, a broken or corroded wire and/or terminal end, dust or moisture on a circuit board, the plate needs cleaning, the contacts for the plate need cleaning, the bulb ballast needs to be replaced, the bulb may not be properly installed, the support posts for the plate need cleaning. These are all I can think of at the moment.
Jun 18, 2008 | Ecoquest Fresh Air Air Purifier
"Replace plate" messge appears. I replaced it but the message remains!
Regarding "Replace Card" warning, 90% of the time it's the female metal connector on the red wire going to the spring metal connection screws... The connector can have a buildup of corrosion ( green) build inside of the crimped connection. In that case, the crimped connector will need to be replaced. The black wire may also suffer from corrosion, but to a lessor extent. The replacement crimps need to be stainless steel crimps. The copper crimps corrode easily. Another thing to look out for are loose connections. The final solution would be to replace the card, or see your friendly dealer.
Nov 08, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Living Air Purifier Logo
83 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
