Sony KP-65WS500 65" Rear Projection Television Logo
Posted on Jan 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The picture looks 3d and is inverted toward the middle> whatever is written on the screen shows up 3 times
Anonymous
Level 3:
  • Sony Master 3,459 Answers
  • Posted on Mar 06, 2010
Anonymous
Sony Master
Level 3:
Answers
3459
Questions
5
Helped
849837
Points
5558
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
the picture looks 3d and is inverted toward the - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Anonymous
Level 2:
Scholar:
  • Expert 62 Answers
  • Posted on Mar 25, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
62
Questions
0
Helped
13687
Points
153
The solution above is good. you will have to change some fuses and the STKs, Also check the resistors linked to STKs. Hope you are able to DIY. But its a professional job. check out the costs & FAQs @ www.fixurtvs.com.
Black screen
Check its back-light inverter and back-light CCFL lamps.
1helpful
2answers
Emerson 37in flat screen Cracked inside out
Get what use you can, there is not a way to "fix" that--the front screen unit is called a display panel and even if it was available the part alone would cost much more than the whole set did when new, time to go shopping for a new set.
Sorry, damage to the screen unit is always fatal.
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
2helpful
Hi I have Dell XPS M1210 laptop. When I turn on the screen nblinks for a second and then goes real dark. at first it look like its gone blank but if you look closly, the screen is on but very dark. I...
farooq473, replace the Inverter.
1) An LCD screen cannot produce enough light by itself. A Backlight is used to help provide the needed light.
2) An Inverter is used to provide power for the LCD screen, and the Backlight.
An Inverter boosts power up for the LCD screen, and lowers it for the Backlight.
90 percent of the time a bad Inverter is the problem.
A Backlight usually goes out all at once, Inverters slowly 'die'.
Dell Support > XPS 1210 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/xpsM1210/en/SM/index.htm
In the list click on > Display
Now click on Display Panel.
Dell doesn't show, and describe how to replace the Inverter.
When you click on Display Panel, you are looking at an exploded photo showing the Display Panel removed.
Scroll down to the next small illustration.
Has 1, 2, 3, 4, and 5 pointing to the Display Panel.
5 shows you a pull tab to release a flat cable from the Inverter. The Inverter is the small circuit board to the left of the pull tab.
This is not advertising for this website. Just an example to show you what the Inverter circuit board looks like.
(Screen Inverter)
http://www.battery-adapter.com/product_info.php/products_id/3450
This is Not a Dell XPS 1210 Notebook PC. It is a guide for replacing an Inverter in a Dell Inspiron 1525 Notebook PC, but I wanted you to have photos, and instructions for the basic procedure.
After you have repaired over 100 laptops, you'll realize that they all have the same basic procedures.
Just different parts.
http://www.insidemylaptop.com/replace-lcd-screen-inverter-dell-inspiron-1525-laptop/
3) Be SURE ALL power is removed from the laptop before you start.
Remove the AC adapter (Charger) and Battery.
4) You should follow Anti-Static Precautions implicitly. It would be best if you bought, and wore an ESD wrist strap. (Electro Static Discharge) Connect the alligator clip to a good ground source.
(For example, I connect to the metal frame of an empty desktop computer case)
The cost averages from $3 to $12.
A $3 ESD wrist strap will do just fine.
This is an example of an ESD wrist strap,
http://www.amazon.com/Cables-Unlimited-ACC-1400-Static-Grounding/dp/B000EDMPQK
5) Use a multi-compartment container for the various screws you will remove.
Label each container for the area the screws came out of.
You DO NOT want to mix them up!
You can use a clean egg carton in a pinch. Label each egg holder.
Have questions post in a Comment.
Regards joecoolvette
Picture problems
Is it one color that has moved? Sounds like a convergence problem. Find a channel with a fixed picture, or if you have digital cable or satellite pull up a guide, something with a straight line across the screen. You will likely see one of the colors is bowed or or shifted. You may be able to adjust that with your remote under the "convergence" adjustments in the menu. If it will not adjust it will need work done to the convergence circuit. Not a DIY project.
4helpful
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
1helpful
2answers
RCA HD56W66 convergence
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Picture is bending at the top and bottom and looks 3d
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
2answers
3d affect
have the dm board checked
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
