Question about Culligan Under Sink Water Filter
My culligan water softner just keeps running .
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
It is most likely running to drain. This is an indication that the seal pack is seized up, generally from a bent piston. You need to by-pass the softener and call Culligan for service. If you are handy there is a retro-fit kit available from Culligan to remedy this problem. It takes about 1/2 hr to install.
RJ
Posted on Jun 04, 2011
3 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
Posted on Jan 24, 2010
h2oservices
  • 306 Answers
SOURCE: culligan water softner
We need clarification as to the nature of your problem before we can provide assistance.
RJ
Posted on May 16, 2011
My Culligan MC450S water softner has a blank flashing display. Water seems to be constantly running through the softner and pressing any display panel buttons has no effect.
This system should be under warranty still. If it is running to drain constantly bypass the system and call Culligan for service. Unplug it for 2 minutes and it may reset.
RJ
Jan 08, 2011 | Culligan Sales #SY-750S Under Sink Water...
I have culligan house water softner. after i changed my hot water heater my softner stopped working. I dont have a manual to check. any suggestions?
Unless the softener was bypassed when the water heater went in, installing a water heater has no bearing on the softener working or not. Is it unplugged?
RJ
Aug 27, 2010 | Culligan 34" Whole House Water Filter...
We have a summer cabin up in Minnesota on a lake on the Measbi Iron Range and the iron content of our water as it comes out of the tap is 240 times greater than the EPA allowable maximum. If we install a...
Water softners will remove approx. 90% of the iron from the water...if this is acceptable then you are okay with the Culligan...if not then you will also have to install an iron removal system in addition to the softner.
Also check around with your local plumbers, as many will install a water softner at a gereatly reduced cost from what the franchises will charge you...and they have just as good a systems and often do a much better installation job.
heatman101
Aug 13, 2010 | Plumbing
Silver water softner sounds like water running all the time
It is running to drain. The sealpack (main piston & sealpack are one unit) is bad and needs to be replaced. If you are handy you can do this yourself. There is a retrofit kit to help repair these issues. It is only available at Culligan. It is about $10.
RJ
May 13, 2010 | Culligan 34" Whole House Water Filter...
Will not stop regenerating water keeps running
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
My culligan mark 89 water softner the salt bin never is used up anymore. its been 2 months now and its still full but i hear it everynight turn on
Try cleaning the filter screen under the metal cover plate. Also check your water supply pressure. Some softeners won't run properly on low pressure.c8a54da.jpg
Sep 03, 2009 | Culligan Sediment Water Filter Heavy Duty
My mark 812 water softener just lets the water run out into the drain cant stop it unless I shut the water off
sometimes the heads go bad on those and they get stuck in a regeneration cycle that just flushes the tank out. put it on bypass or call your softner maker and alot of times they will help you diagnose it and send you replacement parts. also some of the softner heads use small electric motors that get siezed as well
Aug 01, 2009 | Culligan Home
Softner model hi flo 2 water volume about half
The flow packs are not opening properly. There may a restriction in the lines feeding the flow packs or the springs/ diaphrams may be bad. I suggest replacing both flow packs and making sure all lines feeding flow packs are free of oxidized iron and debris.
RJ
Jul 01, 2009 | Culligan Sediment Water Filter
MISSED RINSE on culligan softner
the unit number one needs to be reprogrammed by a professional only it is tricky and ck the motor in the unit this controls the valves turning and water direction control.
Apr 29, 2009 | Culligan Sediment Water Filter
Culligan Under Sink Water Filter Logo
1,299 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Bill Boyd
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
