Question about Chi Mei Corporation 221D-NBC Monitor
Samsung 591s color problem the history of this monitor is the problem is too much brigtness base on my diagnose i found that picture tube have problem, i repalced picture tube from a good and working 591s whice is same model but my only concern is the color comes greenish bias color or back round image,,,i ask you sir/madam if theres any solution to fix and return it on natural color....thanks hope you guys can help on my wierd problem tnx and good day.
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Suddenly my screen becomes only green
On a CRT monitor the usual cause is failure in the picture tube electron gun dealing with the green electron gun. The kathold is shorting out to the first control grid.
There are possible circuit problems that can also cause this, dealing with the driver components to the picture, but this is very rare compared to picture tube failure.
An experienced tech with CRT type monitor service can quickly diagnose the cause of the failure. I can tell you in advance a CRT monitor would be very expensive to service if parts can still be found for it.
Jerry G.
Jul 16, 2012 | HP 98785A 16" Monitor
Samsung syncmaster 591s monitor has red tone
There could be number of reasons, the main one being a power issue. There may be one or more bad capacitors on the circuit board. These can be replaced by someone who knows how to repair electronics but since this is a CRT monitor you need to be very careful about the dangerous voltages inside the monitor.
Considering the age of the monitor you are better off spending the money a decent LCD monitor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
Apr 18, 2012 | Samsung Computers & Internet
Hi, I have a samsung samtron 55V 15 inch monitor. The problem is it is not displaying the actual colors. The red color appears as a greenish/bluish shade. Ex: The Windows Start button is showing as light...
You have to check for dry soldering in the base board of you mointor. The base board is on which is attached to the picture tube neck. In most cases there will be dry soldering in the pins of cathode diver ic in that base board. It will be difficult find out which pin have the dry soldering. Do on thing resolder all the pins of that ic. This ic cotrols the three cathodes of picture tube (red, blue, and geen) is any one did not get the correct drive that color will fail to display. In your case the red cathode is not getting the drive voltage. Thats why it shows only gree and blue. This is a reular complait for crt monitors.
ok
Jul 17, 2011 | SAMTRON 55V 15" CRT Monitor
My syncmaster 591s monitor is showing only green colour
Your picture tube has a problem already, when it goes green. Maybe you can try resetting all the settings to default, when you do so and it doesn't get better then its time to change it.
Mar 14, 2011 | Samsung 793DF 17" CRT Monitor
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Screen is too bright, and all text and videos are blurred
If this is a conventional tube-type monitor, you need to replace it. Your symptom is one of the ways a picture can fail. With the low prices on LCD monitors today, it's completely uneconomical to repair the old one. It would need a new tube.
Apr 08, 2009 | Computers & Internet
I have a yellow haze overall. Color distorted not very clear.
Some reasons for the above problem......
1. Faulty connectors and cable
2. Faulty Picture tube (in case of CRT)
3. Faulty components in monitor's picture tube base circuit board
The same problem will happen when the display section of mothrboard got any complaint
Try these....
1. Try with a new CPU or Monitor and ensure the problem that with Monitor or not
2. If the problem with monitor, try changing the VGA cable
Mar 02, 2009 | LG Flatron F700P 17" CRT Monitor
Samsung crt 591s blank problem
This eventually happens to all CRT monitors. Either the flyback transformer or some other critical componant has failed, and the screen cannot produce a picture. It might be an easy fix, but it would be better to get a new one.
Sep 09, 2008 | Computers & Internet
Samsung 591s monitor
It isn't getting a steady, usable source of power, you can try to diagnose this your self but it will be a power issue INSIDE the monitor within the circuit board
Jan 22, 2008 | SAMTRON 55V 15" CRT Monitor
Chi Mei Corporation 221D-NBC Monitor Logo
98 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
giarcnameloc
Level 1 Expert
Jax Planet
Jax Planet
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
