Question about Toshiba DVR660 DVD Recorder/VCR
Getting audio but no video from vcr and dvd. Attempted different wires. No success
    Scholar:
  • 94 Answers
Try changing the input setting using your TV remote.
Posted on Jan 31, 2010
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
How do I re-connect a VCR/DVD player to a Bravia? I have (!) video output and (1) audio output wire from the VCR unit and have tried a number of combinations without success connecting to the back of the...
The DVD/VCR player should have video (Y) plus right (R) and left (?) outputs that connect to corresponding inputs on the rear of the Bravia TV. You should be able to press the TV/VCR button on the remote to select that device as the input source.
Mar 17, 2017 | Sony BRAVIA KDL-20S3000 20 in. LCD TV
CANNOT SUCCESSFULLY HOOKUP A DVD/VHS TO MY VIZIO MODEL NOS. DVD-v2000 25W
I was the person chatting with you earlier on, before the chat was disconnected. My system went off and I'm sorry about that.
I'm responding here in order to make sure your problem is solved.
LAST QUESTION THIS IS A DVD/VHS DUAL UNIT AND IS CON NECTED WITH THE wHIT rED AND YELLOW TO FROM THE COMPONENT AREA TO THE BACK OF THE TV
You can do the connection by using two different methods: (a.) you can use the component method or (b.) you can use the AV method.
Using the Component method: The component is a combination of red, green and blue wire connection which brings video or display.This three must be connected for you to have a display of your unit on your TV.
Connect the Red, Blue and Green wires respectively to their appropriate places on the TV, then the other part on your DVD/VCR. Note that this connection will only bring a display and no audio. You will have to connect the red and white wire from audio out of the DVD to audio in on the TV.
Once you have successfully done the connection, put on the DVD/VCR and your TV, then press "source" on your TV remote and select component 1 or 2 for you to get a display.
B. Using the AV connection: The Av connection is using the RCA wires which is yellow white and red, just as we discussed while chatting. Connect the Yellow, white and red wires, from the TV to the DVD/VCR, the select AV on the TV remote.
Unlike the Component which its video connection is red, green and blue for display, the AV is only Yellow for display. I hope you under stand this.
Please try to follow my explanations and let me know, if you don't understand and I will explain further.
It was nice chatting with you.
Take care.
May 02, 2010 | Televison & Video
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
No video/audio on tv when powered up and running
drew a diagram of the back of each component & wires/cables and emailed it to my grandson,
The video wires in the VCR were placed out instead of in. That solved the problem Thanks.
Feb 14, 2009 | Sony DVP-S360D DVD Player
I want to record a dvd from my tv/dvd/vcr combo to an external vcr. i'm not trying to break any laws, it's only for my babygirls personal enjoyment. please tell me how the wires should be
as long as you're not breaking any laws you can connect the video/audio output of your combo unit to the video/audio input of your vcr using audio/video rca cables where the yellow plug goes to the video input/output and the red plug to the right audio and the white to the left audio input/output.
Oct 16, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Audio static and video skipping during DVD play
Hello billandanita. Have attempted a disk player cleaning? If not purchase a disk cleaning pack from a local electronics supply/repair store. Asking a local repair shop will get you the best cleaner available. Good Luck.
Sep 29, 2008 | GoVideo Go Video DVD/VCR Combo
I dont know how to hook up my rca receiver to my dvd player and my tv and vcr so i can have it all running i dont know what wires go where
first check your receiver if it has inputs for all those gadgets you wanted connected. in your input function selector see if there are options for your dvd, tv, vcr. if it does have all those inputs then just connect all the audio output left/right rca jacks of your gadgets to each input function of your receiver. your VCR though is different, you have to connect the receiver input to vcr output. the vcr record goes to the vcr input connections. your TV, if it has got any audio out then connect to the audio in function of your receiver.
May 03, 2008 | Audio Players & Recorders
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Quasar 13" TV/VCR combo
not sure y it is b+w since the video is only one and audio is r and l.
Nov 05, 2006 | Quasar VV-1302 13 in. TV/VCR Combo
Toshiba DVR660 DVD Recorder/VCR Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
