Question about Dryers
Dryer got hot and shut down. Cleaned out the vent and now it won't do anything. I check the power and breakers and all it good there. Is there a reset on located inside the dryer somewhere?
  • 254 Answers
No u blew out ur thermal fuse on the backside if its a wirlpool built .... its white part number 3392519 u can see a pi of it at repairclinic.com...... this blows due to overheating its a safety thing it blows and is caused by the vent is either kinked, blocked or ur venting is clogged or vents a long distance.....you must take of the back of the dryer and can check that fuse with a meter for continuity, unplug the unit first though. if it reads sometin is good if nothin dead,, check the thermostats back there as well if its not the fuse... hope this helps
Posted on Jan 31, 2010
My beko dryer keeps tripping my electric box
We had similar problem with a different type dryer. Turned out to be a weak / older / bad breaker in the electrical panel. Every so often it would just trip the breaker for no reason.
The owner thought it was the dryer itself - and bought a new one - but problem remained.
In our case - solved by electrician putting in a new breaker in the panel for the dryer.
Could still be your dryer though, in your case.
Suggest:
- make sure dryer vent is not plugged by lint or other stuff.
[ When running, check that you've got good flow of hot air coming out the outside vent. If NO, could be a plugged up vent. We've had that too before. Disassemble, clear out vent tubes, check for plugged up screens, on the outside too, there is sometimes a screen in the outlet - it could get plugged. The screen is important - to keep out leaves & animals & stuff - but typically gets plugged up. Then dryer overheats and shuts itself off or trips the breaker. Also - you'll find that it takes longer to dry anything if the flow of air going out is restricted.]
Oct 25, 2013 | Dryers
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2012 | Dryers
Replaced timer on dryer because would not shut off sometimes. dryer was working while I had it open I was vacuuming out lint around drum and switches. had door open and light was on suddenly light went out...
if its on a circuit breaker,just switch the breaker off,then back on,they can drop out ,but still show good
if this is not the case,check the incoming power block inside the dryer as a burned off neutral conductor can result in the same condition
Sep 11, 2011 | Dryers
My Amana NED7200TW dryer still shuts down with no power and after a couple minutes it will power up again. I checked the circuit breaker but the breakers were not tripped. Help!
Sounds like an internal over-temp thermostat is tripping. Usually, this is caused by near-zero air flow through the machine. Vacuum out the exhaust hose, the exit fitting from the house, and all of the dryer's interior air path that you can reach. Wash out the lint filter with detergent and HOT water as fabric softener deposits will plug the screen. Check the exterior vent for air flow while it's running--it should be fairly forceful (and hot!). Hope this helps!
Apr 12, 2010 | Amana NED7200TW Electric Dryer
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer runs hot and will not shut down automatically
there is a thermostat or what we would say a high temp switch near the heating element to keep it from getting to hot , the internal parts of the vent must be cleaned as well, cleaning the vent and the screen is not always good enough. Ive had to completely take the dryer apart and pull all pipes apart all the way to the lint screen to fix this problem.
Jul 23, 2009 | Dryers
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Dryer won,t get hot
It's not a circuit breaker your chasing. Check your vent to see if it's clean. You could have a bad element.
Apr 12, 2009 | Amana NDE2330AY Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
