Question about Refrigerators
Need to temporarily move our Whirlpool Gold refrigerator to replace kitchen floor. How do we remove fridge doors so we can get it through the doorway?
  • 454 Answers
Usually, there are bolts/screws on the hinges. They may be covered with a plastic cap which will snap off. Start with the freezer door. While supporting the door, remove the screws from the hinge and lift to free the door. Now you should have access to the hinge supporting the refrigerator door. Same procedure for refrigerator door. Keep the screws in a safe place so you can reassemble the refrigerator when the kitchen floor is done.
Posted on Jan 31, 2010
  • dfstokes06 Dec 23, 2010
    what do u do with the electrical wires running thru the doors because of the light and the dispenser on the door?
  • David Jewell Dec 23, 2010
    There should be a connector somewhere inside the door or inside the refrigerator. If you go to one of the on-line appliance parts dealers, you can look at an exploded view of your refrigerator and see the location of the connector. Once you have disconnected it, you can remove the door.
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Leaking all over from Whirlpool Gold Refrigerator
I think that the seals are ruined when the seals are ruined the water will leak outside and inside beacause all of the heat from outside will gather together and will melt the ice and will make the moisture act up and boost the process of it turning to gas matter into liquid matter.
Apr 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator won't fit thru door.
I ran into the same problem when I moved into my old house. the door way was to small, so I had to take both doors off the refrigerator to get it through the doorway. But I found out when I moved out of the house, that I was able to open both doors and wiggle it through the doorway. It was a hassle but it was alot easier that removing the doors. Good luck.
Apr 04, 2009 | Whirlpool ED2FHGX Side by Side...
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Need to unplug fridge- Whirlpool Gold Side-by-Side
you will have at least a foot of flexable water hose. Pull it out slowly to make sure its not tangled.
Jan 05, 2009 | Whirlpool GD5SHAX Side by Side...
Removing Doors on Whirlpool Gold GS6NHAXVQ side by side fridge
remove the kick plate (lower grill) on the freeezer hinge is a tube folow that tube to a disconect, unscew the nut then remove the nut from the tube then remove the top hinge and lift the door off the lower hinge threading the tube through the lower hinge.
Dec 24, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
