Question about Kenmore Refrigerators
Refrigerator top freezer leaks into the bottom refrigerator.
  • 454 Answers
The drain in the back of your freezer is frozen. When the defrost cycle runs, the water has no where to go except through the panel into your refrigerator.
Turn the refrigerator off. Take everything out of the freezer and store it someplace for a few hours. You can either let the freezer thaw on its own or help it out a bit. If you want to speed the process, remove the rear and bottom panels from the inside of the freezer to expose the coils and the bottom pan. Stay away from the coils. Melt/chip away all of the ice in the pan. With a hair dryer, melt the ice in the back of the pan. Soon you will see the drain - concentrate on melting the ice in it. Some hot water and a sponge can help speed the drain clearing process. When the water drains freely, finish drying out the rest of the freezer and reassemble the rear and bottom panels. Turn the refrigerator back on, and you are good to go.
Posted on Jan 31, 2010
Started leaking water accumulated on bottom shelf in lower level. now top freezer takes 2 days to freeze ice, bottom freezer vent clogged.
The drain is clogged. When the drain clogs it can also clogs the airflow vents. Remove the back wall of the freezer to access the drain. Remove all the ice blocking the drain and the vents. Then use a trukey baser to force hot water down the drain until water flows freely. Then mix water with baken soda and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 27, 2010 | Kenmore Top Freezer Refrigerator
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a amana bottom freezer refrigerator that is cooling the top section
i think you mean its not freezing at the top? if this is so, sounds like you have a gas leak, you cannot fix this yourself unfortunately you may require a technician to fix the leak and top up your gas.. make sure they fix the leak or this will happen again. hope i have helped
Nov 11, 2009 | Amana ARB2257CSL Bottom Freezer...
Refrigerator/freezer door rusting and leaking at
Use DeBruce polish, we find them at debrucepolish.com
Mar 22, 2009 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
I have water leaking heavily from the inside top of refrigerator,
Water is leaking inside the refrigerator from a bottom vent from the freezer. What is causing this?
Feb 27, 2009 | Kenmore Refrigerators
Water leaks into the freezer
under refrigerator you soposed to use hot water
Dec 22, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
