Question about Whirlpool Cabrio WTW6600SBK
Whirlpool Cabrio stopped working mid cycle and came up with F51 error. It runs in a little bit of water, stops working, wait a bit of time, fills will a little more water and repeats process.
  • 129 Answers
CLEAN WATER PUMP
Posted on Jan 31, 2010
Whirlpool Cabrio model WTW7300X washing machine
Did you inspect the area around the drum? You have to take the top off to do that. Then there is a water sensor on the left side. The error that you get is from the drum speed sensor.
Dec 16, 2013 | Whirlpool WTW7300X Top Load Washer
Washer stops at rinse cycle and give the ul code F1
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Its says f51 error
The error means that washer repeatedly quits mid-cycle. Basically, the F51 error is a rotor position sensor error.
Also check the below article for details:
http://cabriof51error.blogspot.com/
http://appliancejunk.com/forums/index.php?topic=1753.0
Thanks,
E-ware
Jul 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio WTW6700TW1 only fills little bit, won't turn or agitate, buzz sound/humming noise,code F51 flashes??
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 16, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Little bit of Water goes in drum does not turn or agitate buzzes and stops working. F 51 flashes?
Jan 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBK Logo
329 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
