Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a whirlpool gold refrigerator side by side the rubber around the door is very hot and the panel that the doors closes on in the middle of the refrigerator gets very hot also. can you tell me what this might be and what i need to do
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
THIS IS A HEATER TO KEEP FROM CONDENSATION MAKE SURE COIL UNDER REF ARE CLEAN AND NO FROST ON THE BACK PANEL
Posted on Jan 31, 2010
Middle panel hot to the touch
This is an indication that the condenser is overheating. It could lead to problems if not addressed. I have put together some instructions on how to remedy this. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
May 12, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
Cold storage door will not stay shut
all of the refrigerator has a spring if there has no spring it will not open and close!
Apr 14, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Panel between doors is hot
Many models of refrigerators have a heating element around where the gasket seals to the fridge. This is to prevent ice buildup around the doors that would prevent the doors from closing all the way.
If you haven't noticed any other problems with the cooling of your unit, you're refrigerator is running exactly the way it was designed.
Mar 26, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Middle bar hot
Hi, Under normal operation the middle bar will be quite warm and under heavy load or higher ambient temperature's sometimes hot, yes it is normal. It is most noticeable following a defrost cycle, new "thawed" item's being placed in the freezer section ( or following someone standing there with the door opened for a lomg time trying to figure out what they want...i.e. my son. lol) and also very hot summer day's.(depending on your geography obvioisly). It is a means in which the manufacturer's has designed to prevent condensation from building in the area commonly referred to as a "perimeter heater/loop". Hope that help's and if so please rate the answer you received from me here at fixya. Thank you andgood luck. macmarkus :)
Dec 07, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Front center panel where doors meet to close are very warm/hot to the touch. Is this normal for this refrigerator?
yes they have heaters in them to help reduce moisture on the ref you can ussually turn them off by turning the energy saver feature on but this may cause moisture to build up on the exterior part and the inside of th ref
Sep 06, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door itself...you see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Jun 05, 2009 | Refrigerators
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
100 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
