Question about Tappan Microwave Ovens
Tappan microwave/no key chime or ending signal,how to turn back on?
  • Tappan Master
  • 9,047 Answers
Try a "hard reset" by unplugging it for a minute or two, then try again.
If you still have trouble, contact us with your full model number for free advice.
Posted on Jan 31, 2010
How do I get to the fuse on my cabinet tappan microwave?
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 28, 2013 | Tappan Microwave Ovens
Installing microwave in center island
hang on..let me see those installation instructions from Tappan's site..back in a minute
Feb 29, 2008 | Tappan TMS062E1 Microwave Oven
Can you disable the chime at the end of the time cycle on my microwave
Yes , You can disconnect the chime or SOFTEN the chime by just insulating the gong if this is mechanical type or to disconnect the buzzer if this is the electronic control board
Jan 10, 2013 | Microwave Ovens
My Tappan TMV 151FS (2008) microwave is not working.
You likely have a door switch or mount. See a handy help file on door switches here.
The service manual for the TMV151 model series is here, and the parts manual is here.
You can order Tappan parts from the Pros here.
Nov 30, 2012 | Tappan TMT104E1 Microwave Oven
Tappan 5030 microwave oven fuse is ok but no lights on keypad come on
see the causes and fix it. God bless you
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | Tappan TMS062E1 Microwave Oven
Goldstar MV-1555ST Microwave The end of cycle chime or end of time chime (probably same component) quit working is this on circuit board? Or can it be replaced seperately.
I was not aware that there was a sound on/off option menu. Read manual and turned back on not sure how it got off definately not on purpose.
Dec 30, 2009 | Goldstar MV-1555ST 1000 Watts Microwave...
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Tappan microwave
I think the membrane/button for the number 4 is stuck or broken. Due to the nature of a microwave my advice would be to entrust the work to a competant technician. Hope this helps.
Oct 01, 2008 | Tappan Microwave Ovens
Tappan microwave from 1995
check with www.microwaveglasstrays.com or call them toll free @ 1-877-894-0035.
Aug 23, 2008 | Tappan TMS062E1 Microwave Oven
Not turning
r u putting heavy stuff on it? if not, then its probably how it is and u should exchange it.
Nov 27, 2007 | Tappan TMS062E1 Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
jdtech
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
