Question about LaCie Computers & Internet
Running a lacie hard drive with mac mini - after 2 years will not show up on desktop or in utility disk window
  • 696 Answers
There are several possible reasons for this.
The most common is a short or failure in the Lacie enclosure caused by mixing up power/AC adapters. If your two Lacie drives are different models and you accidentally used the wrong adapter you may have damaged the circuitry.
The second possiblilty is that your power adapter or USB/Firewire cables could be damaged. Try switching USB/Firewire Cables First. If this fails to work then check if you have a smae sized adapter with the exact same Output Voltage and Amps on both adapters. Only if they are identical try switching adpaters from the working unit. If they are not proceed to the below solution.
Finally if the unit was dropped, bumped or unplugged while it was running it is quite possible that you may have damaged either the drive or the file structure on it, either of which would cause it to stop showing up.
Solution:
Try the cable swaps if able, if they work, replace the USB cable or replace the entire enclosure if the power adapter is the issue.
If neither works then you have either a failed hard drive or failed enclosure. Go to your local PC store (not a big box and yes PC, they tend to have more experience and parts to work with in this type of situation), have the techs there remove the drive from the Lacie enclosure and place it in a new enclosure for testing. They may not be able to see your files but they will be able to tell if the drive is working. If it is, buy the enclosure, then connect the drive back to your Mac. If it works you're done.
If the drive works but the Mac still doesn't recognize it(doesn't show up on the screen), then comment back and I will get you the link to a program you can use to retrieve the lost files.
If the drive simply fails to show up at the store in the new enclosure you will need the help of a pro to recover any important files. If that is the case reply with your location, Country, State and City and I will recomend an appropriate facility for you.
Hope this helps FixYa,
Chris
Posted on Feb 03, 2010
My drive cannot be read by mac os or windows. If i open disk utility on my mac it is seen but cannot be accessed. It does not show up in any other locations on my mac. Windows recognizes the drive but...
sometimes a defective power supply can cause those issues.
Verify that the power supply is silent, no hissing or high pitch noise.
If it there is a hissing or high pitch noise, replacing the power supply with an identical one might fix the problem.
If not, please let me know.
Jan 19, 2011 | LaCie Big Disk (300990U) (LAC300990U) 600...
The icon for my lacie exyernal hard does not show
Here's two suggestions. (If your using Mac OS X 10.x)
Make sure external hard drives are to be shown by clicking "Finder" in the menu bar then "Preferences" and under the "Sidebar" section selecting "External Disks".
Also check that the hard drive is mounting by opening "Disk Utility" by first opening the "Applications" folder then the "Utilities" folder and double clicking "Disk Utility" and in the left sidebar checking to see if your external hard drive is listed as one of the mounted drives. Hope this helps, don't forget to comment/vote if this helped. Thank you.
May 30, 2010 | Apple Computers & Internet
Loud clicking from external lacie hard drive, turn it on then a couple of seconds later it starts clicking, click,click,click,click,click, .....,.....,.....(nothing for about 2-3 seconds)...
The disk-drive inside the casing has a probably-fatal problem.
Search online for a professional "Data Recovery Service";
ship them your disk-drive, they repair it, just long-enough to copy
all your files onto a brand-new disk-drive, or to burn to DVD-recordable media. Their services are _EXPENSIVE_ -- but "invaluable".
Jan 03, 2010 | LaCie (300770) 250 GB Hard Drive
My external hard disc worked well until today. Now the external light continues to flicker quickly and the hard disc does not show up on my desk top. I have a mac running Mac OS X 10.5.7. The serial...
There is some thing wrong with file system on your hard disk drive.
Just unplugg it and wait for 1 min, Plugin again.
1) Go to Application -> Utility -> Disk Utility
2) You can see all the drives connected to the machine.
3) Select the drive from left side which acts as external and click on Repair disk button.
Sep 18, 2009 | LaCie Computers & Internet
My Lacie HD will not show up on my MacBookPro when plugged
Brand new? It needs to be formatted / erased with the disk utility to work with your mac.
Jul 07, 2009 | LaCie (300728U) 250 GB Hard Drive
My Porsche Lacie 160GB disk no longer mounts on my Mac OS X. OS is fully up to date at 10.5.6. I've tried it with different firewire cables and on multiple Macs. One is a dual G4 desktop, the other is a...
You need to back up data from the drive and then connect your drive on MAC you need to use mac utility to format the hard disk in Mac as some times it wont recognize a windows operating system...
Jan 08, 2009 | Computers & Internet
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie HD won't show up on Mac desktop, quit showing up yesterday
Hello! Had the same problem - go onto the Lacie official website. Select whatever type of drive that it is you have, and simply go onto the software update page. I literally downloaded the desktop manager (I own the Sam Hecht Little Disk) and it appeared! Good luck
Nov 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
I need to download the LACIE setup assistant and can't find my software. Does anyone know where I can find this program to download. I need to format my Lacie drive for windows. Thanks
Please click on the below link or copy the URL and paste it in your web browser. And follow the steps. To download the drivers click on the Download which is present in the right side of the document.
http://www.lacie.com/support/faq/faq.htm?faqid=10550
OR
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Lacie-USB-2-Driver.shtml
OR
http://list.driverguide.com/list/company1220/
Thank you.......
Sep 24, 2008 | LaCie Computers & Internet
Mounting an external hard drive onto my I Mac
Hi, I have just checked the LACIE website, So Google LACIE, click the second result [Lacie's own site] you will get a page up with a choice box, select Australia/go click the desktop HDD. click the 500Gb usb, this will give you a page with a support and a download link. click download, here you will find a manual and drivers. Goodluck mistyman
Sep 03, 2007 | Computers & Internet
Computers & Internet Logo
180 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
