Question about HP Pavilion m7100y (PX189AV) PC Desktop
Audio icon is recognizing speakers but showing not plugged in
Audio is showing speakers but computer says it's not plugged in
  1. Go to control pannel
  2. Go to sound and audio device
  3. Go to audio
  4. nd select ur audio company which is manifacture by motherboard company
Posted on Jan 31, 2010
I have installes windows 7 ultimate in my asus p4 motherboard but sound is not coming inspite of plugging speakers its shows unplugged
Try with another pair of headphones or speakers. If the computer is not recognizing there are audio devices plugged in there may be a problem with the audio jacks or sound drivers.
Having all of the windows updates and drivers updated (inside Device manager) will help.
Feb 09, 2012 | ASUS Computers & Internet
When i plug in the speakers no sound is coming out it doesn't work correctly i cant hear anything i'm playing.
Hi taceeg06,
Have you check all the Volume setting on you computer?
On the lower right side look for the computer Icon check if there is a red X on the speaker Icon, if there is then it can be that here is something wrong with the speaker driver or it does not detect the speakers.
If you do not see the speaker Icon then the Driver for the Audio card is not installed on the computer and you may need to re install that Audio Card Driver to be able to regain the audio from your Speakers.
Also the speakers should connect to the Green Audio Jack behind the computer, if it is then still no Audio you can try the Audio Jack in front of the computer as well to check the Audio Card in the Machine, if the front and back audio jacks do not detect nor produce sound when the speakers are connected then re installing the driver for the Audio card may work, unless during the installation an error shows that the there is no audio device detected then it means the Audio Card is busted.
Let us hope not since it is very seldom an Audio Card could go busted.
I hope this helps.
Have nice day,
mvincentc
Jun 12, 2011 | Insignia 2.0 Speaker System (2-Piece)
Hi i have the Bose companion 5 speakers today there was a power cut in my flat. after that my speakers are not working anymore. the thing is that the led on volume control is on (green) and my pc...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 30, 2011 | Bose Companion 5 Multimedia Speaker System...
How can i get an audio?
You will have to be more detailed in your question. In order to get audio you would obviously need an audio device such as speakers or headphones. You would then need to make sure your computer recognizes this device and the sound isn't muted. You can often find out whether or not the computer recognizes a device or is / isn't muted by checking in the bottom right hand corner on the speaker icon. (assuming you have windows)
Mar 02, 2011 | Computers & Internet
Philips speakers wont work on dell desktop
I'm assuming you have plugged the speaker wires into the correct ports.
In Control panel, pick the sound icon and click to open it, do you have the sound driver showing (it will say no audio device if you do not).
If not, download the driver from the motherboard or sound card manufacturer
Check the desktop speaker icon is not disabled
Check the line out is set to high
Repost if these don't solve the problem
Jan 01, 2011 | Philips (DBMMS460) Computer Speakers
Will Harman Kardan speakers work with a Dell? If so, how?
if it is through a headphone jack the computer will never recognize the speakers you'll have to right click on the speaker icon on your tool bar lower right corner and select adjust audio properties the click advance and select desktop speakers,
Jun 03, 2010 | Audio Players & Recorders
My dell computer will not recognize the logitech speakers. I think it is something to do with the usb plug in versus a normal "jack" type plug in. I am using Vista as my OS>
Ok firstly make sure that the the speakers are connected to the green port at the back of the system tower. connect the usb cable to the usb port.
check with a headphone if there is sound . If sound is present then connect the speakers as above and then click start control panel - sounds - on this screen see if the speaker icon has a green check mark beside it , if not then click on the speakers and click use default device option present at the bottom of the screen. This should fix it.
In cases where the screen is greyed out .
strt - rgt click on computer - manage - device manager - audio device - chcek if ter is a yellow ! or red X beside it al;so check if you see other devices on screen
You could reinstall the audio drivers from the dell website support.dell.com for a DELL desktop . Reinstalling audio drivers should fix it.
try using the speaker on other system .
Hope its informative :)
Mar 31, 2010 | Logitech X-120 Computer Speakers
I have some multi speakers but the volume not coming out
You don't give me much to go on so here is everything that I can think of:
Remember that there are two volume settings. The volume knob on the speakers and the volume in the computer. Make sure the speaker and computer volume is up and Mute is off.
Make sure the speakers have power. Most of them have a light to show that they are on.
Make sure the speakers are plugged into the the right port on the computer. The audio out port is usually color-coded green.
You can plug a pair of headphones into the computers audio port to see if they work. This will tell you if the problem is with the computer or the speakers. (Don't put the headphones on for this test, the sound might be very loud.)
The last thing would be if a sound driver is not installed on your computer. If you have a sound driver there is usually a small speaker icon next to your clock. No speaker icon and you may need a driver. You can download a sound/audio driver from your computer manufacturer's website.
I hope this helps.
Jan 29, 2010 | Computers & Internet
Speakers keep cutting out when they are plugged in and a high pitch squeal comes out of computer speaker
How many Audio ports do you have in the back of your computer? Also, what Audio DRIVERS do you have installed in your computer? If you have REALTEK audio drivers, it SHOULD automatically recognize the speakers are being plugged in and change that ports usage over to speaker output, but not all drivers do this. It could simply be that you're plugging them into the wrong port audio port if you have 4 - 6 back there, as some motherboards do. Try different audio plugs and see if that works for you.
Jul 06, 2009 | Logitech X-240 Computer Speakers
Speakers not working, but cables all plugged in...
the problem is your computer may not sense the presence of your audio device, chances are your driver is either corrupted nor not yet installed.
go to my computer then right click go to properties, hardware, device manager,
under the device manager go to sounds and see if ther is any exclamation icon or anything , expand this icon and see if there is anything you see that has a yellow exclamation or question mark right click that icon and select scan for hardware changes , then update driver , better yet go to sound properties and see if you can roll back the driver, if you have the cd utilities for your computer, you can reinstall the driver again and after all this restart once again your computer
cheers
Nov 08, 2008 | Logitech X-530 Computer Speakers
Open Questions:
See all HP Pavilion m7100y (PX189AV) PC Desktop Questions
HP Pavilion m7100y (PX189AV) PC Desktop Logo
100 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
