Question about Northstar Generator 9 Hp, 5500 Watt, Gasoline
Gas flowing out of in line ??? - Northstar Generator 9 Hp, 5500 Watt, Gasoline
  • 714 Answers
RECOMENDATION:
Turn off Fuel valve.
Hope this tip helps.
R/
David
Posted on Jan 31, 2010
What does the flashing B mean on the hours display of a craftsman pro series lawn tractor mean
must have somthing in tank tack off clean it out real good chang fuel finter claen carb out blow lines out reinstall tank put fresh gas in not old gas check fuel pump when priming it thats about all you can do shoud be under warranty
Aug 23, 2014 | Garden
Gas will not flow from tank to motor while running
Everybody had a crack at this problem, another thing would check is these engines sometimes have a primary fuel filter inside the tank itself. Drain the fuel and gently blow compressed air back through fuel line towards tank then rinse the tank out with fuel, refill and try run engine again
Aug 07, 2014 | Honda 8 HP Engine
How to empty gas tank
Pull gas line from gas tank to carburetor/injector/throttle body.
If carb, turn on petcock, allowing gas to flow into a gas can.
Remove gas cap to improve/increase flow.
If injected, turn on ignition to cause fuel pump to turn on, flowing fuel under pressure into gas can.
Oct 28, 2013 | 2011 Aprilia SR 50 R Factory
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
I have a SureFire Grill (SF30HOLP) that I recently converted to NG. For some reason the gas will flow through the regular and light, but at times I am not getting gas through the regulator. I have a...
I would try replacing the regulator, not very expensive and easy to do, first. If that doesn't fix the problem, call the gas company and see if there is a flow problem to the line itself. I have worked on grills that were operating properly, but there just wasn't enough gas flow in the line for the grill.
Jul 04, 2011 | Surefire Grilling
Fuel pump working perfectily just no power going to it when i turn key
SENDING UNIT ,GAS LINE INTERUPT, TAKE THE GAS LINE OUT WHERE DELIVER THE GAS IN THE INTAKE AT FRONT IN THE ENGINE HAVE SOME ONE TO CHECK FOR THE GAS FLOW WHEN YOU JUST TRY TO STAR THE CAR,TO SEE IF THERE IS A GAS FLOW WITH ENOUGHF STRENG, ,,,,,,,,,WARNING JUST HIT THE CAR KEY FOR A SECONG JUST TO SEE THE FLOW AND COVER ANYTHING WITH A RAG THAT MIGTH REPRESENT A POSSIBLE RISK OF TURN ON FIRE. IF GAS NOT COMING OUT AND THE GAS PUMP IS OK THEN THE GAS LINE IS BAD.GOOD LUCK
May 19, 2011 | BMW 525 Cars & Trucks
One side glows like a champ. The other side, dedicated for High setting, pooffs when I turn it to high, then kind of fickers and barely glows. I have a fuel filter and a six foot hose off of a 20#...
dirt , foriegn material,spider web in gas feed line to the right side ceramic element of mr heater big buddy. take plastic back of heater
off, many #1 philips or smaller screws. find large air induction holes
in gas feed line to right side ceramic element and blow out with compressed air and fine tiped /straw tipped air blow gun.
straw tipped air blow gun is a better tool for this.
reassemble & try lit mr heater again.
If it dont work after air blow gun the gas feed tube, you didnt get the gas feed tube cleaned out ,***** & span (something still in there ) and will need to disassemble the gas feed tube and inspect for foreign material blocking the gas flow.
If this dont work,need to take the gas feed line off the gas valve attached to Mr. heater red knob. red knob just pulls straight out, might need pliers to grab red knob.
check gas valve output for dirt etc that stop gas from getting through. check inside the gas line to the ceramic burner for dirt,
foriegn material- that stop gas from flowing through strong.
any stopage of gas flow , even a slight stopage or dirverting of the gas flow, spider web is common, will stop ceramic element from burning properly.
needs to be clean ,like a carburator.
Dec 27, 2010 | Mr. Heater Big Buddy Heater
Priming bulb not working tecumpseh 10 hp snowthrower model unknown
turn the gas line valve to on, remove the gas fill cap, remove the gas line from the carb. gas should be flowing freely. if it is, put the line back on carb and try the primer again. if it is not flowing freely you are pluged at the tank.
Dec 02, 2009 | Mastercraft Garden
Gas Range has inconsistent gas flow
From what you've described and what I understand; the only part that requlates the gas flow "low or intermitten gas flow/pressure" is the "gas pressure regulator" located where the incoming gas flex-line connects directly.
The pressure regulator is about 3" x 3" metal square blockish' type device and can be replaced fairly easy. However, if and when replacing the pressure regulator, ensure you are using the proper gas - yellow teflyon tape of pipe dope paste to thread in the new part.
What is the model number of the range? (free standing - gas pilot only)
(The above suggestion is assuming you have the proper gas supply pressure to your home/range)
Jan 27, 2009 | Hotpoint RGB745 Gas Kitchen Range
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
50 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
