Question about InFocus X1 Multimedia Projector
Infocus x3 video problem
After 2 years of excellent work (~1800h of lamp usage), a dark (not black) band appeared at the left 1/10 portion of the screen. Looks like it's getting wider week after week. Any ideas how to get rid of it?
Thank you
  • Anonymous Jun 24, 2008
    i am also having the same problem and it also happened after i replaced
    the bulb, i thought it was the new bulb that was defective but technical support
    over at infocus told me that it is unlikely... (fixing it would cost
    almost like a new projector) does anyone know how to fix this?
  • Valerie Ward Jul 23, 2008
    Oh My! I thought my TV (projector) was dead! I figured it had been bumped around to much when i moved from one town to another. I cant wait to get home and dismantle it! I hope i find a mirror that fell off. If not... it wasnt working anyway! Wish me Luck... I love fix ya!
I had this happen to me. I was able to fix it. It was indeed the light tube. The glue connecting the four rectangular mirrors had peeled from the heat and one of the mirrors had slipped and fallen in. Oddly enough, some well-placed scotch tape managed to hold the light tube together correctly, and it's been working fine ever since.
http://bobbaddeley.com/doku.php/blog/surgery_on_my_baby
Posted on Jul 01, 2008
    Problem Solver:
  • 17 Answers
Sounds like it could be the mirror tunnel. There is a very small mirror tunnel behind the color wheel (looks like a long prism) that can often fail as it is very fragile. This tunnel concentrates and channels the light to the DLP chip and if it collapses it can cause the very issue you describe.
Posted on Feb 19, 2008
  • 14 Answers
Had the same thing on my LG projector - indeed the mirror light tunnel that collects light from the bulb and projects it via a set of subsequent mirrors to the DLP imager. The glue holding the 4 tunnel mirrors together came loose and one mirror slipped inwards to create a grey band on the TV image. I removed the mirror tunnel and had to rebuild it. I cut a long piece of wood in rectangular shape so I could stack the mirrors around it and hold them in place with small rubber bands. The stick was as wide as the widest mirror and as high as the narrow mirrors. I then applied silicon in the gaps between the mirrors and scraped the excess off so it won't interfere with alignment of the tunnel again. After curing of the silicon, I extracted the wooden stick to leave a perfectly shaped light tunnel. When you refit the tunnel, make sure that it lines up correctly otherwise it could cause grey bands at the edge of the TV image.
Good luck if you want to do this, as it is a very nerve-wrecking and finicky job! Projectors don't like to be worked on - lots of little connectors, small screws and things that can break. With a new bulb after 3000hrs, the image is bright again, but I think if this one wears out, I will upgrade to newer technology.
Posted on Sep 14, 2008
Try this link:
http://www.avsforum.com/avs-vb/archive/index.php/t-618877.html
Posted on Jun 24, 2008
I am also having the same problem and it also happened after i replaced the bulb, i thought it was the new bulb that was defective but technical support over at infocus told me that it is unlikely... (fixing it would cost almost like a new projector) does anyone know how to fix this?
I am having a similar problem with mine, but it happen after I replaced the bulb. Is there any way to fix it myself?
Posted on Apr 26, 2008
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
Nov 26, 2012 | Televison & Video
Have sound but picture looks like this in every port of the tv.
Digital processor board is faulty. Contact any experienced service technician.
Nov 25, 2012 | Televison & Video
Dark Band on Samsung projection TV
most likely optical engine issue----bad light engine.
Aug 27, 2012 | Samsung BP96-01073A E-Series Replacement...
I have a Sony Grand Wega KF-60WE610 television. It now seems that the picture is darker than it used to be. I can still watch a show, but many people who have seen my television comment on the poor...
I'm sorry that the pictures on the TV screen is black. Based on the information you have provided, it appears that the issue is with the Lamp itself. The lamp of the TV may have to be replaced within two to three years depends upon the amount of usage.
If the screen becomes dark, the color looks unsual or the LAMP indicator on the front of the LCD projection TV flashes, it is time to replace the lamp.
Thanks for understanding. Please let me know if you require further assistance in replacing the lamp of the TV.
Jun 08, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
Dark band at top of screen...now whole screen
Pop sound is probably the Lamp or maybe the color wheel. When you unplug and try it on do you hear a whirling or winning sound ? Is it followed by a slight ticking sound ? If you get the whirling and a ticking sound it's probably a bad lamp. If you don't hear the whirling sound you may have a bad color wheel. The parts are both made of glass. The pop you heard was one of them breaking. If you can't tell, order a lamp you will need to change it eventually anyway.
Apr 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Rear projection TV (LG 44SZ51): Horizontal dark band on upper screen field
The LG 44SZ21RB Have a problem with their light tunnel collasping due to the heat from the lamp. They are available as a spare part @ LG and would also require some silicon adhesive to bond it into the assembly. Very tedious job for any technican (2-3 hrs). Lg will not release parts to the general public only to an authorised LG agent.
Mar 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
InFocus X1 Multimedia Projector Logo
2,026 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
