Question about Toshiba 32A33 32" TV
Burnt Resistor I have a toshiba television model 2909XH with 2 of the resistors burnt R443 and R306,can u help me to find out the value?
  • 5,603 Answers
There are LIKELY other bad components that caused this. Resistors USUALLY don't fail on their own.
Posted on Jan 30, 2010
Burn Resistor 842 conot find the value
You can get the value of this resistor from the circuit diagram of your model TV.
Usually a burnt resistor is caused by some other component failing that is connected to the resistor.
Apr 19, 2013 | LG Televison & Video
I have a Toshiba projection T.V, model number 43J7DM.It is dead
247 is .050 watt15K ohm
404 is 0,25Watt 1K ohm
420 is 0.5 watt 10K ohm
513 is 0.25watt 100 ohm
However if you dont understand them dont play around with them you may end up doing more damage than what you have now. If resistors blow then some other fault has caused excess power to fuse them and that takes knowledge of how to measure the current at each step. Some of these resistors are related to the power board. Getting circuit diagrams from toshiba is difficult Quite often there is a diagram inside the chassis of each model.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Toshiba 55H70 55" Rear Projection...
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
Looking for resistor value on Toshiba PB7243 Power convergence PCB Resistor is R7731 part of bias for convergence IC I think.. but looks burnt
R7711, R7721,
R7116, R7726, R7736, and R7731. are MF, 1.2 ohm, 2W resistors--MF means metal film or metal oxide--check all of them if you are replacing the two STK-392-110 CHIPS---
They are protect resistors in case some part of either chip shorts--if even one is bad--you need to replace both chips at the same time and adjust.
If you need help or advice let me know--I am here to help.
If this information helped you rate this solution as I do this here for free.
SD TECH
Jan 02, 2010 | Toshiba 55H70 55" Rear Projection...
The blue convergence seems to be off on the tv, and i'm not sure how to fix it
Take the back of the tv off but first unplug it Then look to the lower right and you should see 2 convergence IC's (STK392-110) and also look for a burnt resistor around them. If no burnt resistors replace convergence IC's with STK392-180 If you have a burnt resistor then respond back to me with location number on the board and I will get back to you with the value.
Jun 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
WILL NOT TURN ON
Sir;
friend of mind had the same model # and he give me the color band for the resistor
Nov 18, 2008 | Yamaha HTR-5560 Receiver
Resisters questions
Its best to replace both IC's. As far as the resistors, there are location #'s marked on the board where the resistors are mounted. If any look burnt, get the location numbers off the board, and your model # and email me @ halselectronics@comcast.net. I will get you the resistor values.
Aug 10, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Burnt out resistor
I was not able to find a free service manual download. Here's is a site that has the service manual but is a pay site. click here.
Jul 03, 2008 | Samsung Televison & Video
Magnavox resistor problem
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
Toshiba 57H82 resistor value???
When I get to work in a few hours, I will get the value for you.
Yes,you can use a regular 1/4 watt resistor and you might be
able to measure the value of it's twin in the other IC circuit....T.
Jan 21, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 32A33 32" TV Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
