Question about Amana SXD524VW Side by Side Refrigerator
Amana srd2553w sidebyside will not dispense water. was working fine until i changed the filter on our water system. water is in the line with pressure to the bottom of the door but will not go up the door and be dispensed.
  • 1,531 Answers
There is a chamce there is frozen water in the supply tube in the door this can be cleared using a blow dryer
Posted on Jan 31, 2010
Why is my side by side leaking water from left wall after replacing water filter inside on right side?
The problem is the water line to the dispenser is broken. The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
May 27, 2012 | Amana Refrigerators
Amana AR2664bw dispenser lights
Are you talking about the inside lights are the dispenser lights?
Nov 01, 2008 | Amana Refrigerators
Why is my refrigerator leaking water after changing water filter?
I changed my water filter but the filter status light still says to change. How do I get it to go to ok status.
Simply press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for four (4) seconds until the filter status indicator begins to flash, then release the buttons. On some Amana refrigerators, you need to press the dispenser lock and water buttons for four (4) seconds until the filter status indicator begins to flash, then release the buttons.
Feb 01, 2011 | Amana Refrigerators
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hot point sidebyside hh228859 ice dispenser works fine (crushed and cubes) but no water dispenses
if you can hear a click or buzz when you push water dispenser change the inlet valve if not test for power at the switch
Aug 06, 2009 | Refrigerators
Water dispenser not working
The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Amana ARS2464B Side by Side Refrigerator
No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
Jan 18, 2009 | Amana SXD524VW Side by Side Refrigerator
No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
306 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
