Question about Dell 924 All-in-One InkJet Printer
The printer keeps jamming with the paper only going half way through and the grinding noise keeps going as if it is continuing to print. It appears as though it is hanging.
  • 4,041 Answers
Hi
Try looking at the thin little belt that drives the heads from one side to the other it maybe slipping or the bar it slides on is dry and is sticking try only a little oil on the bar with a cloth.
All The Best: Pineworks
Posted on Jan 31, 2010
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
Grinding noise
Hi Anonymous
I trust you are well
If you hear a grinding noise it might be the gear wheel in the printer that is stripped or possibly a paper jam.
Hope this helps
Kind regards
Aug 20, 2014 | Canon Office Equipment & Supplies
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
OFFICE JET 7410 PRINTER
Check the cartiridge if it is sitting nicely on its place. it seems you dint place the cartirdge properly
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Grinding Noise and no printing
grinding is NOT cool...i'd say that you have a mechanism issue with this printer. How long have you know this printer?
Mar 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Grinding noise/paper jam
Fuser drive gear is a mission to install
Dec 30, 2007 | Brother MFC-8840D All-In-One Laser Printer
Dell 924 All-in-One InkJet Printer Logo
70 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
