Question about Samsung YP-Q1JEB/XEU Digital Media Player
Samsung YP Q1 16GB touchpad torture
I have a Samsung YP Q1 4GB and have had no problems. The touchpad is OK once you get used to it, and works fine through a silicon skin. I just bought a 16GB model and I find the touchpad to be almost impossible to operate, as the up position is very insensitive and the OK (centre) function is oversensitive. It doesn't respond at all through the skin. Anyone got any ideas before I go for a refund?
Computer not "seeing" device/driver failing to install
i had recently bought this mp3 and had the same problem as you. i went online and read many solutions about drivers and stuff... geez! after 6 hours of frustration and researching online. i almost decided to blast the mp3 out of its misery. LOL! but i used my brain and i had finally solved my problem.
install samsung media on pc
turn on your samsung yp-u3
go to settings
go to system
go to format
select yes
COMPLETE MP3 FORMAT
NEXT PLUG MP3 INTO USB
go to control panel
system
hardware tab
device manager
samsung yp-u3
driver tab
update driver
wait for completion of update
abra caddabra! mp3 is now ok.
-=jericho=-
Oct 19, 2009 | Samsung YP-U3 MP3 Player
SKINS
if its a silicon skin than just slip it on
Jun 23, 2009 | Samsung YP-S5 MP3 Player
Samsung media studio??
You have to update the driver of you player.
Click on START menu and RUN.
Type in devmgmt.msc and click ENTER.
Now you Device Manager will pop up. Look for your player under Other Devices or Portable Devices
Once you find it, right click on it and select Update Driver (make sure the installer disc is in your CD drive).
It should work fine after that.
Nov 27, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-Z5 can't scroll
This is a common problem with these players. It is a hardware fault with the touch panel. It is probably why they were replaced with new models very quickly afterwards. The touch panel is a complete unit added to the device.
If you can get hold of a faulty unit on e-bay (with a working touchpad) you can easily replace the the touchpad without damaging any part of the mp3 player as it easily unscrews.
Jan 21, 2008 | Samsung YP-K3 MP3 Player
Touchpad not working
If you have a wireless mouse or a USB mouse plug in and get online to find a downloadable driver for your touch-pad. A lot of file adding and shifting with a touch-pad can get the system fragmented (Defragging may help) and driver files, .dll's, and others your touch-pad needs and uses can get buried in the clutter (file fragments) all over the floor so-to-speak. If defragmentation of your hard drive doesn't work just download new drivers. Here is a safe Download link to look in. There is just about everything here, free and safe too...
Mouse Drivers software for Windows Free Software Apps and Games
May 24, 2017 | Samsung Yepp YP-Z5QB MP3 Player
Samsung YP-Z5
From my experience this is a hardware fault with the touchpad. Luckily you can buy a faulty player on ebay and replace the touchpad - make sure the fault on the faulty one is not the same!
The player is is easy to take apart and the touchpad easy to replace.
Nov 20, 2007 | Samsung YP-Z5 MP3 Player
Samsung yp-z5 scroll panel stopped working.
This is a common hardware fault with this player. I guess it is why the model has been replaced.
The cheapest solution is to buy a faulty player from ebay - around £10 including postage and replace your faulty one. Make sure to check the faulty one does not have the touchpad fault.
It is straightforward to replace the touchpad.
Oct 23, 2007 | Samsung YP-Z5 MP3 Player
Touch pad will not work
did u get some water on it too like me?
Oct 13, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Touchpad not responding
The touchpad problem is a hardware fault. I have bought a couple faulty ones of these with this problem. I bought some other faulty ones from ebay and just replaced the touchpads. It is easy enough to do.
The good thing about the player is it is easy to take apart and replace anything and wont leave it looking like a wreck when you are finished.
Oct 07, 2007 | Samsung YP-Z5 MP3 Player
Big problem
I had the same issue.
Format the mp3 player again choosing "restore defaults of the device" (and format using FAT).
It will work again
Jan 16, 2007 | Samsung Yepp YP-U1X MP3 Player
Samsung YP-Q1JEB/XEU  Digital Media Player Logo
90 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
