Question about TruTech PLV16190 Television
We hardly use our TV, but a couple of days ago when I tried to change the channel, the channels started changing by themselves; like it was possesed. I tried using it again a few days later, and it will not change to another channel but the one it is currently on; not by remote or manually. How do we fix this?
    Genius:
  • 1,121 Answers
This is a stucked key on tv, check for any keys dirt
Posted on Jan 30, 2010
Old tv buttons got wet
The tv buttons are actually small "tact" switches which are contaminated with the vinegar and shorting themselves. Unfortunately replacing these is your only option. You may get lucky to just turn if off and let air dry for a few days.
Mar 13, 2014 | RCA F25254GY 25" TV
I have had a Sharp AQUOS LC-46PD7X for over three years and just a couple of days ago I started getting a problem where I turn the TV on and it either displays a digital channel for a couple of minutes and...
Hi ibrahl,
I too have the same model and vintage and have been experiencing low signal problems for quiet some time now. It only became apparent when we hooked up the ps3 playTV unit and the digital channels we were having problems with on the Aquos was broadcasting fine. Both devices use the same antenna connection so its not an aerial issue.
I tried reset back to factory settings and reloaded the channels via auto but now those digital channels I had problems no longer appear on our channel list so they're gone for now. I was wondering the same thing about firmware updates but havent found anything on the Sharp website. Found this video but this model uses USB for updates">
Jan 02, 2011 | Sharp Televison & Video
My 27" Standard TV is showing all channels and movies widescreen
on some remotes there is a button to do this and can only be done using this button-
if you have a sky box or other you can go into services/picture settings and change format here.
if in dout R.T.F.M................lol
Aug 06, 2009 | GE 25GT240 25" TV
My tv is stuck on a channel
You have a problem with a internal circuit.you can try by, powering off the tv for about one day. then turn it on again
Dec 15, 2008 | Proscan PS32125 32" TV
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Ghost in the channel selector
the problems due to the microprocessor on the remote reciever present inside the tv .i think the remote is normal working. as the only problem with your iinfra red reciever microprocessor.microcontroler circuit. Replace the IC to solve this. Check electrolytic capacitor coupled to the memory block of the micro processor. Contact service if you are not well verse doing all this rectification works. it is off high risk and caution
thank you !
Nov 17, 2007 | RCA F36650 36" TV
Blurry Screen
ok your problem is the RGB section maybe crack soldered at the RGB try to resoldered it! you seen that at the back of the picture tube they have small board attach at the neck... resoldred all small part, and transistor drivers!!!
Nov 13, 2006 | Jensen TS2750J TV
Channels change by themselves ??? please help
its mosy likly the remote control sensor inside the set. had the sam problem a couple of times already. I'll post the part # when I can find it
Mar 27, 2006 | RCA P52955 52" Rear Projection Television
TruTech PLV16190 Television Logo
100 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
