Question about Dual XAF-340 Car Audio Amplifier
Resistor size... What size is R55? I would very much like to know
  • 5,603 Answers
You likely will not be able to find a schematic.
HINT: most of these amps are stereo and there is a second copy of the circuit for the second channel.
OFTEN the layout is VERY symetrical and a minimum of circuit tracing will reveal R55's brother in the second channel.
Posted on Jan 30, 2010
Resistor going to my pto clutch burnt out
Your going to have to call the factory/customer service and find out what the resistor size is.Got Radio Shack and get a couple of them and solder one in.You don't want to run it strait without the resistor,could burn up something MORE important.Like the clutch.You can get Husqvarna online help too.Try Husqvarna.com.This new stuff can be a pain at times,but gotta havit.Rigger
Aug 28, 2012 | Cars & Trucks
R55 model. runs for a while & cuts off. [1]
Dials? I assume you are speaking of the air pump adjustment screws.
How to set the pump pressure
Nov 20, 2010 | Reddy R60A Utility Heater
R55 reddy heater takes 5 seconds to fire
I SUGGEST U GO TO THE FOLLOWING WEBSITE:
http://www.reddyparts.com/
HERE U WILL FIND THE INFO U NEED.
Dec 20, 2009 | Heating & Cooling
Reddy Heater R55 concerns
They are grounds, and should have two screws on the burner tray to hold it from moving. On my heater this is where the grounds get attached. It gives the igniter a dedicated direct ground.
Jan 10, 2009 | Reddy Heater-30-55,000 BTU Variable
Recording from computer to a Sony MZ-R55 mini disc
You can use RK-G136 or RK-G129 cable to transfer music in MZ-R55, insert cable in Line-In terminal.
Nov 27, 2008 | Sony Walkman MZ-NH600 Personal MiniDisc...
Kenwood X590 - LCD Display Gone
Resolder all the resistors. They say 2.7 in the manual, but the print on the component is 2R7. For solder use 60-40 rosin core with flux. The thickness should be a small diameter, but most any solder will work, you will only be putting a very small dab of solder on each solder connection. Just enough to make it melt and reflow, no more. This is no guarantee that it will fix your unit, but it is the most common cause. You may find that the display being out for yours is something different. If you have a voltmeter you can put the radio on a bench and check the voltages (DC) on those resistors when it is powered on. You will need a small power supply capable of about 3 amps to power up a car stereo. I don't remember what the voltage are supposed to be, but you should start at one end and have a high voltage and as you go from one resistor to another, the voltage will go down in equal increments. It is a voltage ladder and with all the resistors being the same value, you should have the same voltage across each resistor.
Nov 22, 2008 | Car Audio & Video
Rca TV HD52W58
The number you gave for the resistor is incorrect. But I did find a R14705. This resistor is a 1/2W 27K ohm resistor. This part is also in the deflection circuit. This is not a good circuit to play in, and resistor do not burn up by them selfs. There is a problem somewere neir by. The part number for this resistor is 238958.
Jul 31, 2008 | RCA HD52W58 52" TV
Dual XAF-340 Car Audio Amplifier Logo
48 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
