Question about Samsung LN-T4061F 40 in. LCD HDTV
Black/Dark Colors Fuzzy w/Red Pixel Outline
I purchased a Samsung Lnt4061fx/xxa 40" LCD a few days ago. When I view anything on the TV, black and dark regions appear fuzzy with poor shading and WORST of all show a cloud of red pixels around the circumferance of the dark region.
Any bright and lightly colored scenes look fantastic, but dark parts are nearly unwatchable due to it.
Can this be repaired? Should I return the TV?
  • 2 more comments
  • Anonymous Feb 20, 2008
    Having the exact same problem with my samsung. Any idea what the issue was
  • Canute1980 Apr 08, 2008
    I have an Acer laptop that appears to replace (absolute) black pixels with red. This is an intermittent problem but usually occurs when the laptop has been out of use for a weekend. The last time it happened was when I allowed the battery to discharge and then recharge.
    It has been affected by desktop changes from 'wallpaper' to 'none' and switching-off 'Norton 360' sometimes corrects the image.
  • lcdprob Apr 10, 2008
    I have the same problem too. Do you know what the problem is? Can it be fixed?
  • Anonymous Mar 25, 2014
    TV is on a good part of the day. The colors are fine in the morning but both color and brightness fade during day. At night screen is almost completely black.
Was told the problem lies with the cable between the board and screen by an engineer.
GL
Posted on Jun 24, 2008
I'm having the same problem for a wile with my Samsung LCD TV SGLN40M81BXXAZ. it's pretty annoying
tried a lot of suff and so far nothing. i'm calling customer support since it's already under warranty. As soon as i got an answer post here for you.
  • Daniel Fassa Jun 24, 2008
    I've been looking all over the net for at least a tip of what might been going on with our tvs and monitors, the only place i found something that has some consistency with the described problem was on apple, check this link:http://support.apple.com/kb/HT1721
    i'm still waiting for samsung customer support and then let u know.
I have the same problem too....
Posted on Jun 19, 2008
Sorry, I haven't been on here for a while.
I haven't found the cause. I find that leaving it switched on overnight cures it.
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Tip
Why the white or black spot on LCD Display
Dead and Stuck Pixels <br /> Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel. <br /> A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background. <br /> A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed. <br /> Hope this helps, if so do rate the Tip
on Jan 16, 2011 | Televison & Video
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Black line (strip of pixels not working) horizontal across screen
If a whole line of pixels is dark, you've got a bad transistor in what's called a "Passive Matrix" display. For your future purchasing decisions, while an "Active Matrix" display costs a little more, it has individual transistors for each pixel, rather than one per row and column, so when a transistor goes bad, it only turns one pixel black rather than a whole row or column.
Sep 12, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Black pixels in shading and back ground turning red
This is not a "rear projection" plasma TV for whiuch you offered solutions, It is the LCD Flat panel the Liquid Crystal Display a 40" Samsung. I do not think this problem is a dead pixel as that woulde be "black" Reading on the web I found only one post that appeared to be the same or similar and the person said somehing about "switching the red wire" Maybe it is a "stuck" pixel -- sticks on red once in a while. Like previously after the first time it occured it has not come back in three days now. Samsungs repair comes today i will cross my fingers.
Jun 29, 2009 | Epson Livingstation LS57P2 57" Rear...
Green outline/shadow on dark images or backgrounds
LVDS Cable is corroded - This is the cable the provides video from the TV Video Process board to the LCD Panels Timing Control Board.
Honestly, if you can take the TV back do so. If not, Service it using the manufacturer warranty
Jun 24, 2009 | Vizio Televison & Video
ASTAR 40" LCD / Pixel constantly on
No Sir,
pixel are come from the screen panel. All LCD TV have these pixel and some do shows and some don't. Also depending quality of the screen panel. (These should be counted panel defective) according the information through the LCD factory.
Oct 17, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Samsung LN-T4061F 40 in. LCD HDTV Logo
914 people viewed this question
Henry  Thomas
Henry Thomas
