Question about NEC DS1000 66-Block with AMP connector (S66M1-50-3T25) Phone (S66M1503T25)
I HAVE A TELEPHONE SYSTEM WITH ONE PHONE NUMBER, BUT 25 EXTENSIONS. 23 OF THEM GETS A DIAL TONE, BUT TWO OF THEM DON'T. I DID TRY TO REPLACE THE PHONE JACK WITH A NEW PHONE JACK THAT I BOUGHT FROM HARDWARE STORE, BUT STILL NO DIAL TONE. I EVEN REPLACED THE PHONE, BUT SAME IS THE CASE. WHAT CAN I DO?
    Problem Solver:
  • 5 Answers
A lot of questions need to be answered. But for starters, the other two phones probably do not have the line programmed into them. If these two phones light up...have any other working features then it's not the phones or jacks it's the programming. All phone systems have "line assignment"/ "line access" programming.
What make and model of system do you have?
P.S. On a separate topic, you should definitely have more than one line in your system for that many telephones.
Posted on Jan 30, 2010
My phone says "Line in use" but nobody is using it.
Some of my telephones will read "Line In Use" when the phone doesn't detect a dial tone. I like to use an old wired telephone to check whether the problem is with the cordless phone base or the phone line wiring.
First plug in the test phone and check for a dial tone. If there is no dial tone, try a different RJ-11 cable between the phone and the jack. If there is still no dial tone, use the test phone at another jack and check for a dial tone. If you have two jacks with no dial tone, find your incoming telephone service box. If you have a relatively new phone service installation, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for a dial tone. If there is still no dial tone, contact your telephone company. They will repair an outside wiring problem for free. If the service box doesn't have an RJ-11 jack, you'll need to ask your telephone company to test the phone line for you.
If there is a dial tone at another jack or at the service box, you have an inside wiring problem. You can check for loose or broken wires inside of the jack. Most use either screw terminals or a punch-down design. For the screw terminals, strip another section of the unbroken part of the wire, if needed. Secure the wire under the screw. For the punch-down terminal, take off the cover. Then you'll need a tool that is available in most hardware stores in the electrical wiring section. Do not strip the wire; just place it over the correct place in the terminal and push it into the contacts with the tool. Trim off any excess wire with a small pair of small wire cutting pliers, if the excess wire is blocking the cover from fitting back onto the terminal. http://www.lanshack.com/wire_phone_jack.aspx has a good diagram of the wire color and pin assignments. If the wiring is okay at the jack, you'll need to check the rest of the wiring for problems. Since the broken wire might be inside the wall, you may want to have a professional check it out. Your telephone provider's technicians can do this for a fee. If you have a DSL computer line, you should check the DSL filter. If the filter is inside at the jack, you'll need to replace the filter. If it is out at the service box, your telephone company will do the replacement.
If there is a dial tone at the jack with the test phone, check the purchase date on the L401 system. If it is under warranty (1 year usually), contact Motorola. Otherwise, replace your Motorola phone system. It's generally not worth the minimum repair and shipping costs.
I hope this helps.
(I've had dial tone issues after lightning strikes (the DSL filter was damaged), mice eating wires (buried phone line) and due to county road crew/contractors who dug too close to the wire. The first two problems required phone calls to get a technician to fix the outside line. The last one gets fixed by the contractors/phone company as soon as they can.)
Nov 09, 2015 | Motorola L401 DECT 6.0 Digital Cordless...
How do I intergrate a KX-TD 7896 into existing phone system?
Take one of the existing extensions on the system and listen with a normal telephone if you get Dial tone...Then if you do Plug in your Cordless phone and listen if you do get it then... If not..most probably the cordless is faulty.
May 27, 2014 | Panasonic KX-TD7896 Cordless Phone
When using phone I cannot call out , it gives me a fast dial tone , but I can get incoming calls
Does the fast dial tone persist, or do you get a regular dial tone after a couple of seconds? If the latter, then you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 16, 2014 | Panasonic High quality max 2.4 ghz phone...
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
"No such station" message appears when I try to
It means there's "No Such Station" :-)
VM extensions are part of the system, usually the pilot number is the lowest of the sequence. If your button got reprogrammed and you're dialing a number that doesn't exist, you'll get that error.
Start by dialing like 22, 23, 24, 25 (4 highest ports in a 0816 DSU). Reprogram the button by Intercom **1 press the button and dial 6xx where xx is the VM pilot number.
Carl
Jun 23, 2011 | Comdial 8012S-GT Corded Phone
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
There is no dial tone for fax, why
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 08, 2010 | Brother IntelliFAX 4100 Laser Fax
No dial tone when pressing hook fax is returned
Apr 06, 2010 | Brother Multi-Function Center MFC-240C...
TIME CHANGE
Hi!
System Time/Date can be set via admin programming or using feature code 692.
To set using the feature code:
1. Dial [692] on the dial pad. A confirmation tone will sound.
2. Enter date and time as follows: YYMMDDHHMM
When the correct number of digits are entered, a confirmation tone will sound.
3. Press the ON/OFF button (SPEAKER button on IP Phone) to OFF to update the display.
YY = Year (00-99) HH = Hour (00-23)
MM = Month (01-12) MM = Minute (00-59)
DD = Day (01-31)
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 26, 2009 | Vodavi 30-Button XTS Telephone
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
NEC DS1000 66-Block with AMP connector (S66M1-50-3T25) Phone (S66M1503T25) Logo
77 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
