Question about Insignia NSDSC10A Digital Camera
Insignia camera turns on beeps three times and turns back off
    Champion:
  • 312 Answers
Three beeps indicates a low battery or other warning. It also indicates error messages, such as memory full or card error. You should try replacing the batteries, erasing files from the memory, or verifying that your memory card is in the correct format and/or not defective. Additional details can be found in the owner's manual.
Posted on Feb 05, 2010
Insignia camera turns off with three beeps
The camera is trying to turn on, but either the lens is stuck, causing an overload in an effort to turn the motor that, through gears, extends the lens. That's a common problem, and the 2nd most common problem is that the batteries are not holding enough charge to drive the motor, contacts are dirty, things like that. There are 2 excellent web blogs that detail the problems, and what you can check and try. Here they are:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Good luck, and hope this helps.
Jul 13, 2010 | Cameras
When camera turns on it shows the insignia sign, gives 3 beeps then turns off. What could be the problem?
Hi there 3 beeps means system error. Remove the memory card and try again. If you get the beeps again then the problem occur in Lens. Its stuck from in side. Its happens when the guide pin is damaged or dislocated. In that case you have to visit service center. After remove the card if problem solve then before fix back the card please, format it and use. I hope your problem will solve then. Thanks.
Apr 11, 2010 | Insignia NSDSC10A Digital Camera
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
Insignia NSDSC10A Digital Camera Logo
436 people viewed this question
Top Insignia Cameras Experts
Electric Dime
Electric Dime
Greg P
Greg P
Are you an Insignia Camera Expert? Answer questions, earn points and help others
