Question about Whirlpool Kitchen Ranges
Cook top works but oven isnt. igniter clicks, oven smells gas, but its not burning. i have a whirlpool model gs563lxsq. thank you
  • 254 Answers
Sounds like ur ignitor or glow bar is bad... replace that bake ignitor usually a sgr403 if round ignitor, or a 12400035 if flat style these are two kinda generic ,, if u want the whirlpool part u will pay double these parts are the same thing just made by diefferetn manufacture ,, u can see pics of these parts at repairclinic.com hope this helps
Posted on Jan 31, 2010
The oven will not ignite its a whirlpool model sf380pew
Hi
Thanks for using FixYa. The air holes on the side of the burner that faces the center of the stove may be clogged or holes near the oven are clogged which are leading to uncompleted combustion of the fuel and thus leading to the foul smell. This helps the pilot or spark igniter to light the gas. Try cleaning the holes with a toothpick.
Heating elements eventually burn out. Sometimes, when an element burns out, you can see that the coil burns in too, or blisters and bubbles.
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
Igniter is made up of a crystal which gets damaged or distorted physically and wont work fine until replaced. This may lead to incomplete combustion of fuel and is a safety hazard.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 26, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven does not light
first check the igniter to see the color of it. if it is orange you need to replace it because it is too weak to ignite. it needs to glow white hot. second, the burning smell could be from the coil, check the coils as well near the gas valve.
Nov 08, 2009 | Ovens
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
My Whirlpool gas range model #GS563LXSQ during cooking will lockup and shut down, what causes this?
possible overheating.high limit may be tripping as a safety.may want to check thermostat,or high limit safety.
Oct 09, 2009 | Whirlpool Kitchen Ranges
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Gas oven clicks but doesnt ignite
Not getting gas so check gas outlet in the bottom of the oven for clogs , if not clogged the thermostat is bad
Jul 22, 2017 | Ovens
Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Jan 24, 2008 | Whirlpool SB160PEE Gas Single Oven
Kitchen Ranges Logo
126 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
