Question about HP Computers & Internet
I deleted the configcheck file and am still gettin the code purple help!!!
  • 3 Answers
Reinstall OS
Posted on Feb 09, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sniper:
  • 81 Answers
Your computer needs to be repaired
Its a hardware faliure(MOTHERBOARD)
Posted on Feb 04, 2010
Code purple in windows 7
This is a trap door setup by HP to ensure you only use their hardware (i.e. motherboard) with their software. Here's what to do: after the system recovery is done, boot up a stand-alone CD (e.g. BART, UBCD4Win) that allows you to edit a file. Ensure you can see hidden files and go into
C:\hp\bin\ConfigCheck\cfgchk.bat
Either delete or remark-out the line that calls the run.py script.
Save the updated .bat file and reboot. You should now be able to continue the XP setup.
Jun 27, 2012 | Computers & Internet
Unable to open sms inbox. When i click on inbox it is stuck there, No video recordings are gettin saved. All media mp3 files from gallery deleted
formate please the code is *7370# if proublem is same please update your phone to next version.
any good mobile repair shop.
Mar 19, 2011 | Nokia N72 Cellular Phone
I RECIEVED THE CODE PURPLE BECUASE I CHANGED MY MOTHERBOARD. HOW DO I FIX OR GET AROUND CODE PURPLE?
Put your hard drive in a different computer and edit the file:(your system drive letter):\hp\bin\ConfigCheck\cfgchk.bat. Remove the line "python c:\hp\bin\ConfigCheck\run.py" and save. Return your drive here & then your system should boot up O.K
Jan 26, 2011 | HP PC Desktop
How to fix code purple error
for windows XP:
- Get into C:\hp\bin\CheckConfig\cfgchk.bat
- Rename the file "run.py" to "run.p_" or just delete it. (That's the file that verify the hardware configuration for the OEM version)
- Then reboot!
for vista:
- Get into C:\hp\bin\CheckDMI folder
- Rename the file "CheckDMI.cmd" to "CheckDMI"
or
- Edit the file and change the "0" (zero) value (there is only one in the whole file) for "1" value...which means that the hardware configuration respect the terms of the OEM contract.
- Then reboot!
Sep 19, 2010 | Computers & Internet
Catalytic converter is purple colored and check engine light is throwin a code for converter. Wondering if gas is gettin dump in converter turning it purple. I f that's the case what cause gas to leak in...
the cat converter is f....d if its purple cos it got too hot, the inside melted......replace asap.too rich a mixture will hurt it but the o2 sensor will go first.poss its just worn out.....
Aug 24, 2010 | 1996 Oldsmobile LSS
I need to purchase an internal power unit for my Philips LS1400 - how can I find out the technical specifications for the unit?
1. Load the first system recovery disk into the CD-ROM drive
2. Press R for the recover console
3. Press Alt + D to bring up the command prompt*
4. at the C:\minint\system32> prompt, type "del h:\hp\bin\configcheck" (without the quotation marks) and press Enter
5. At the "Are you sure?" prompt, type "y" (without the quotation marks) and press enter
6. At the prompt, type "exit" (without the quotation marks) and press Enter
7. Press Alt + Q
8. Press Q to quit the Recovery Window (The PC will automatically begin to boot. You should now be free of the Vastly Evil Code Purple.)
*I have found that there is no need to Select "Advanced Options" prior to pressing Alt + D.
Procedure to recover from "Code Purple" WITHOUT a Recovery Disk Set:
If the Recovery Partition on your hard drive is intact, this should work:
1. Turn on PC and repeatedly press F10 (pause for a second between key presses) until the Recovery Screen comes up
7. Press Alt + Q (The PC will automatically begin to boot. You should now be free of the Vastly Evil Code Purple.)
Jul 24, 2009 | Computers & Internet
I have a code puple on my HP PC a350n..HP says they won't fix it. I thought there was a law suit about this and they Have to fix it. But, I just want to know if ANYONE can.
Code Purple is about the weirdest error you will see reinstalling XP, and it is almost exclusively an HP/Compaq problem.
These companies placed a special system identifier on the motherboard by a process called 'tattooing', and the system recovery routines look for this signature before allowing the install.
It is actually quite easy to bypass this signature check. Here are two entries from an online thread expaining how:
Code Purple can be bypassed by accessing and renaming the file run.py to run.p_. The file is found at c:\hp\bin\configcheck\run.py"
To access the "C:" drive to rename the file:
1. Boot the system with a Win Xp Original Disk.
2. When you have to select "Enter" to reload or "R" for Recovery Console select "R".
3. Select the "H:\minint" Drive to bring up the System
4. At the "H:\minint" prompt, change to the "C:" prompt
5. Change directory to the "C:\hp\bin\configcheck"
6. Rename the file with the command "ren run.py run.p_"
7. Reboot the machine and there should be no "Code Purple" error.
The full thread can be read here:) Note how far it goes back!
http://www.techimo.com/forum/applications-operating-systems/50892-xp-configuration-error-code-purple.html
Please post comments on your progress and results or contact me for more instruction on how to accomplish this.
Jan 04, 2009 | Computers & Internet
Invalid XML
just reset ur internet explre webv setting clar cookis and delete temp file
Oct 18, 2008 | Yahoo Mail
Configuration error code purple
1. Load the system recovery disk into CD-ROM
2. Press F10 repeatedly at boot screen to load the Recovery Menu
3. Press R for the recover console
4. Select "Advanced Options"
5. Press Alt + D to bring up the command prompt
6. type "cd h:\" to enter the root directory
7. type "dir /w" to view the directory in wide view
8. open the master.log file (or something along those lines), this should bring up a prompt asking you what program to open it with, you should only be able to select notepad.
9. open the file with notepad and when it appears select the File>Open
10. in the file name box type in "C:\hp\bin\configcheck\run.py"
11. once the file opens clear the contents and select save as then save the file as run.p_
12. close the notepad program
13. delete the original file by typing "del C:\hp\bin\configcheck\run.py"
14. reboot system
After a reboot the windows screen might flash a few times and take a little longer to load, be patient and you should be able to continue with the windows set-up without that damned code purple error message.
Oct 02, 2008 | Computers & Internet
Code purple error on hp 1410n
"Code Purple" on an Windows XP system: This Worked for me!:
Okay, I have read and read and read, on this site, and on others, trying to fix the "Code Purple" problem. Many of the answers ALMOST worked for me; but I, like many others, couldn't get to the H: drive to del the key file. At the C:\ prompt, I couldn't CD to H:\. So what I did was to give the DEL command from the C:\ prompt. See below for the 2 detailed procedures. The first is for those who have the Recovery Disk Set, the other is for those without the set. Good Luck!
Procedures for recovery from "Code Purple" on a Windows XP system:
Procedure to recover from "Code Purple" WITH a Recovery Disk Set:
7. Press Alt + Q
Jul 08, 2008 | HP Computers & Internet
Computers & Internet Logo
63 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
