Question about iRiver iFP-790 MP3 Player
Not seen by pc
Hey!
I bought an iRiver in '06 and downloaded the software on my pc. Everything worked fine at first, but as soon as i tried to download the software onto my new pc, the problem began.
The software downloads with autoplay, but the pc doesn't pick the player up from my usb port.
Help?!
  • antoniogrime Dec 30, 2008
    yes i have the same promblem i cant get music on my i river ifp-790 from the pc
You would have to use irivers manager software, or change the firmware so Windows can see it.
Posted on Jun 19, 2008
Iriver B30 can't connect to PC
driver is need.search in net
Dec 05, 2009 | Computers & Internet
Iriver Clix 2 8GB connecting to PC problem
Usually it have to, but if is not use iriver plus software !! or see if u have drivers properly installed.
Apr 28, 2009 | iRiver Clix Digital Media Player
I was trying to turn off my iriver, but now it is frozen in the shutdown screen. Prior to that I had it connected to the computer, with the iriver software running. It tried to read the iriver, got stuck...
connect Iriver back to PC...go to my computer open Iriver and copy the software only (hidden files too) you do have your files on the pc and or the cd's.....because you are about to format the Iriver (this will erase everything) open a temp folder to hold software on PC.......copy/paste software to .......now go back to my computer right click to format the Iriver . once format is complete copy/paste the software back from PC to Iriver...now copy/paste all your mp3 files from PC/cds to Iriver.......its like new all over again
Apr 17, 2009 | iRiver E100 Digital Media Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Cant find free download of iriver plus 2
Here's the iRiver Plus 3 software:
http://www.iriver.com.au/iriver/uploads/software/iplus3_setup_full.zip
It's compatible with XP and below. I haven't come across a Vista driver for it yet, but you might be able to right click on it and hit Properties and select XP compatibility in Vista, I don't know if it'll work though.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | iRiver E10 Digital Media Player
New hard drive has trouble downloading songs & won't play
hi there, open iriver again and take new drive out (reinstall hard drive, just an adjustment process). close it up and try to download / play a file.
now if this process dont work, save iriver software to pc and format the hard drive (this will erase the hard drive songs and all)..now reinstall the software from the pc...download your songs back to iriver and you should have a brand new Iriver ihp-140............if heplful feel free to rate
Oct 22, 2008 | iRiver iHP-140 MP3 Player
System files missing
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
Iriver plus software closes down when I plug in my iriver E10 to the computer
Using Explorer try copying one song over into the music folder of the device. Then restart Plus so that it searches and finds a song present.
Sep 13, 2007 | iRiver E10 Digital Media Player
Iriver T10 will not allow me to add songs
The updater that I could find directly via iRiver support did not work, but based on one of the other tips, I googled for the Version 2.7.0.0 updater ([MTP] iriver Firmware Updater for MTP devices).
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
I recommend that you try the "normal" updater from the website (maybe yours is not an MTP version), and if that can't recognize your player, try the updater from the link above.
Note: The updater seemed to hang at 50% for over 5 minutes... I gave up and unplugged it. Then it asked me if I wanted to upgrade the firmware. "OK," I said. It took a few minutes. The screen went blank. I put in a fresh battery. Turned it on. It works. I was able to use Media player 11 to synch some songs to it.
BTW: It did blow away all the songs on the device, even though I chose "update" instead of "recover".
Dec 27, 2006 | iRiver T10 MP3 Player
My h10 will not switch on, iriver support will not help
Try to reinstall the software CD you received with the player. Good luck
May 01, 2006 | iRiver H10 MP3 Player
iRiver iFP-790 MP3 Player Logo
61 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
