Question about HP Officejet 5610 All-In-One InkJet Printer
Printer not Recognised
I have installed All the printer drivers but when i plug in the printer a popup appears saying USB device not recognised My printer is a 5610 ALL-In-One printer please help me my job is at staek
    Brigadier General:
  • 6,966 Answers
Depending on your Operating System, the problem may be due to or you may need to:
1. check if in the printer properties, the port setting is set to USB;
2. If you are using Windows Vista, you may need to initially resolve the USB errors before moving on to making your printer work. This is a known Vista issue and Microsoft has issued a patch/update to resolve this problem. Pls try here or here.
3. update the USB drivers of your motherboard from the manufacturer's website rather than that of Microsoft;
4. uninstall and re-install including the USB controllers and not only the printer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 18, 2008
  • Louie  Role
    Louie Role Feb 18, 2008
    Sorry the link did not get posted.
    #2 should read as "...Pls try here or here...."
How do I fix my brother printer USB not recognised
See if you can find the printer driver online (manufacturer's web-page maybe) and install the driver before you connect the printer.
Aug 19, 2016 | Brother DCP Office Equipment & Supplies
USB device not recognised. One of the USB devices attached to tis computer has malfunctioned and Windows does not recognise it?
you may have to. remove and reinstall the printer properties. good-day ! sometimes this will work.
Dec 13, 2011 | Office Equipment & Supplies
When I turn my printer on I get the USB device not recognised message - says the device has malfunctioned and no matter what troubleshooting tips/steps I follow nothing seems to change it. Everything seems...
It is possible that there are errors in the driver software and so a reinstallation is needed. So remove printer and then open programs to uninstall the printer software. Now shut down and then restart download the drivers and install , connect the printer ONLY when prompted and then check .
This might clear the issue , if not there are problems in the mother board.
Sep 03, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
When printers USB cable is plugged in it is not recognised. Driver installs ok butcomputer does not communivate with printer.
Unless your printer main board has failed, the only reason that a USB connection would not communicate is if your printer is turned off or if the USB printer cable or connection is faulty. Try connecting other equipment with the cable and see if that gets recognised by your computer also try connecting to a different USB socket on your computer.
Hope this helps.
Jan 22, 2011 | Xerox Phaser 3150/B Laser Printer
My HP xe4500 laptop will not complete the installation of the driver for my new HP cp1217 laser printer. At the point where I am told to connect the usb cable, it throws an error message saying something...
Well u need to install the drivers properly..
Might be possible that u would had installed ur driver previously. I'll suggest u to remove the previous installed driver & now try to install the driver again, say fresh driver installation..
Now when u are asked to plug in the usb cable, click later or no & continue..
later when every wizard of installation is completed, restart ur machine once... Now after restarting, now plug in ur usb printer cable...
Even after that u find that device is not recognized, go to device manager from My Computer's Properties..
Select go to USB Section ( Always the Last Option)
Expand the tab & select the unknown device..
Uninstall it & then press F5. Now again a pop up wil occur, now follow the instructions & install the driver manually..
I hope this will work out.. If not, feel free to ask.. I'll love to help u...
If u like my post, please rate me up, i really need some good ratings..
Thanks !!!
Sep 10, 2009 | HP OmniBook XE4500 Notebook
Usb device not recognised
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
My printer has been working ok but now says usb device not recognised tried reinstalling software but still the same message
First you check the USB port is working or not. If no plz update/install the USB driver. if working properly so plz check the connectors which are connected in the computer and another side in the printer. After that uninstall the drivers and install software agin in your computer. I hpoe your problem will solved
Aug 13, 2009 | Lexmark X2550 All-In-One Printer
Usb device not recognised HP 1005
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | HP LaserJet 1005w Printer
USB malfunctioned message
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly
Nov 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
same problem, solved changing usb cable...even if it is working with different devices...
Aug 02, 2008 | Canon PIXMA MX310 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
