Question about Dishwashers
The spray arm doesn't turn, soap stay in the tray and dishes are not clean.
  • 1,531 Answers
Make sure ther is enough water in the unit when running once you start the machine check your water level if you dont see enough in the bottom of the dishwasher add a couple of potfuls of water to it then try and runn the cycle if it runs then your fill valve is bad and needs to be replaed if there is no change then the main wash motor needs to be replaced
Posted on Jan 31, 2010
Soap remains on the dishes after the wash cycle is complete.
Check that the holes in the spray arms haven't blocked up and the filters in the bottom are clean. The arms may not be rotating. To check this, when the machine is washing, open the door, turn all the spray arms to face the same direction, shut the door and leave running for about 30 seconds. Open the door again and look at the position of the spray arms. They should have moved.
Nov 25, 2013 | Samsung DMT400RHS Builtin Dishwasher
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
I have a ge quietpower 3 dishwasher. Lately it has stopped cleaning the dishes. Sometimes the dispenser tray doesn't open. Sometimes it does open and the soap pac hasn't disolved.
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 10, 2011 | Maytag Dishwasher
The detegent doesn't completely leave the soap dish. the soap door works appropiately --- but the dishes do not come out clean. We have tried detergent pellet, liquid detegent and the basic cascade...
This model relies on the top spray arm to 'wash' the detergent out of the soap dispenser - and that is the problem. Your top spray arm will not be turning properly. Check the angled jet on the very tip of the arms for blockages with food or fruit pips etc - it's this angle only that makes the arms turn.
if blocked, clean out with a pin or wire, and running water - make sure you get every bit out. If not, buy a new spray arm. If the arm is split, you will need a new one.
Other problems may be low water level or a faulty circulation pump - BUT check the spray arms first.
Remember a dishwasher is NOT a garbage disposal unit, so scrape any food particles of plates etc before putting them in the machine. Run a dishwasher cleaner through with no load once in awhile.
Feb 04, 2018 | Crosley Dishwashers
Model DU40JV does not clean dishes.
hello when you load the machine make sure the spray arms rotate freely i'e the forks an knifes are not sticking through the bottom of the plastic tray. also check the arms for strapped food in the holes hope it helps
shaun
Jan 13, 2010 | Dishwashers
Dishwasher runs but the dishes aren't clean and low water pressure out of the arms dish soap left in the dishsoap tray
Try some Lime Away or high strength vinegar, to remove any scale from the pump. If it is not scalely, try to remove the spray arms to check if the pump has trash in it.
Sep 19, 2009 | Dishwashers
Soap
1. You have poor pressure coming from the pump. fix this by removing the racks from dishwasher and removing/cleaning the intake filter to the pump. It is located on the floor of the dishwasher. Use a wet vac if you have it to clean the entire area and anything that might be stuck down in the pump. you would be suprised what you find doen there. Don't be afraid to remove a few phillips screws to remove a cover to the impeller. After this all should work better/cleaner AND soap dish will be washed out too.
2. make sure dishes are not stacked to block the soap dish from water spray arms.
3. remove spray arms and clean them out, especially the spray tips. Hard objects will stick in their spray tips.
Good Luck
Jul 29, 2009 | Maytag DWU9962 Dishwasher
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
  • filter
  • . Detergent or Detergent Cup
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Soap build up on dishwasher. Dries white and stays on dishes.
    the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
    Larry
    Nov 25, 2008 | Dishwashers
    Dishwashers Logo
    52 people viewed this question
    Top Dishwashers Experts
