Question about DeLonghi BAR 14 Espresso Machine
Delonghi bar 18 oump driven esp maker won't pump water
Are there any solutions available. the machine works fine but will not pump water through the pump, it seems the sound like it is trying to work, but am not sure about cleaning or service instructions available. thanks
  • Anonymous Mar 22, 2014
    water does not go into machine from reservoir-no sound of it pumping.
  • 22 Answers
It may be a stupid suggestion but have you checked the strainer in the reservoir? It Could be blocked. And if you haven't removed the brew head sieve recently? It could be gunked up.
For cleaning it's best t use citric acid packets sold in stores as it hurts the metals inside the tank the least, but in a pinch you can use vinegar, although it's much more corrosive and could hurt the machine.
When using a cleaner remove the brew head sieve, as a lot of junk will collect and can block the sieve, with resulting no flow for brewing.
Hope this helps!
Posted on Mar 22, 2010
Hi , coffee machine is not heating water, pump working ok, just no hot water!
fest see if you do descaling may halpe to clean the boiler also see ntc which is the thermostat this part is based on the boiler with two leads attached to it this looks after the temperature if not you have to consider the pcb
Mar 26, 2016 | DeLonghi Icona 15-Bar Pump Driven...
Broken water pump espresso
check with the manufacturer's website . they may replace it .
Dec 28, 2015 | DeLonghi Icona 15-Bar Pump Driven...
Wrong elec. out let 220v
You mean the device is for 110VAC only ? Have a look at the rating plate on it. Unless that says input 110V - 220V it is most likely fried.
May 14, 2015 | DeLonghi EC270 15-Bar Pump Driven...
How can i fix the pressure?
Run vinegar through mnachine to remove hard water deposits which have restructed the flow. .
Nov 26, 2014 | DeLonghi Icona 15-Bar Pump Driven...
New out of the box. won't dispence water to make espresso
Hi. Is your pump working. Should be able to hear it. If its making a really loud noise then it could be an air lock in the line. Try using the hot water button to bleed the system. Also see if it will despence water wiyhout any coffee in handle. Dazza REPAIRER
Sep 23, 2011 | DeLonghi EC155 Espresso Machine
I have a De'Longhi EC330S Pump Espresso Maker, 15 Bar it has been making great coffee for a year, but now the seals have blown and water just pours out from everywhere. Can it be repaired?
The problem seals on my EC330S are the one on the steam frother shaft and the connecting pipe from the pump to the boiler. The steam frother shaft seals are available from Buyspares.co.uk but the ones on the pipe from the pump are not available from them even though the pipe is. Mine are leaking badly so will have to look for some from a seal manufacturer if DeLonghi can't supply them.
Feb 09, 2011 | DeLonghi Pump Espresso Machine Stainless...
How to clean bar 14
Cleaning the calcium carbonate accumulated inside the boiler.Put only 200 ml of water in the water tank then add a 100 grams of citric acid cristals.Do not use coffee holder and open the machine and wait the heater ready lamp .Start the pump .Collect the pumpes acidic water in a cup.When the cup is filled stop the pump and recyle the water collected in the cup to water tank.Ater repeating this recycling 2 -4 times all crystals will be dissolved and the boiler will be filled with this weak acid solution.Wait the machine closed 2 hours.Then put fresh water and run the pump and remove the solution.Now your machine is free of scales inside the boiler. You will notice less noise during boiling of water inside the boiler(not pump noise).After some usage if you notice again that high noise of water boling it is time for another cleaning.
Oct 22, 2008 | DeLonghi BAR 14 Espresso Machine
Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Mar 06, 2008 | DeLonghi EC140 Espresso Machine
DeLonghi BAR 14 Espresso Machine Logo
560 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
