I tried to upgrade ram on my toshiba a215-s7462 installed new memory turned it on and nothing. put old memory in and nothing . tried recovery disk and nothing
  • 2 more comments
  • babidoll143 Jan 30, 2010
    tried what you said still have nothing
    tried the easer nothing no errors because sceen is black hd is not coming on
    there are only two slots and that is where i put the old memory back into
    never mind i got it
  • 542 Answers
This is due to dust is accumulated on the RAM(memory) slot. Clean the RAM slot using vacume cleaner and reinsert the memory module will solve your problem.
Revert back for more assistance.
Posted on Jan 30, 2010
  • Rajesh Pai
    Rajesh Pai Jan 30, 2010
    Also clean the RAM pins using eraser.
    One more thing i want know that, you are getting any display or errors??
  • Rajesh Pai
    Try to insert the RAM into other free memory slot and check.
When I try to update Bios on Toshiba Satellite A215-S7462 The computer 'locks up' (becomes completely unresponsive), and the computer's display goes blank (turns off).
Updating the BIOS usually brings up some problems. It burns the motherboard. I suggest that you contact Toshiba regarding this for warranty support.
Dec 11, 2012 | Toshiba Satellite A215-S4747 Notebook
Upgrading BIOS! If it isn't broken don't fix it. Upgrading is a scapegoat fix, and many manufactures have a disclaimer. "You are on you own", and the likes for a reason. Most solutions are found elsewhere. However, if you truly need to update read this to help you with the upgrade. You don't want to end up with a brick. http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Dec 10, 2012 | Computers & Internet
System recovery disk will not load vista on my Toshiba Satellite A215. I get following message the instruction @0x77d62613 referenced memory @0x00d2188a. DMI.EXE error: 03-EEEE-0000
Ohhh not good. and you may not have needed a reload. Try removing and replacing the RAM, if issue remains, try replacing RAM with "known good" ram. Ram does fail. If still no go, time for a bench diagnostic by a technician.
Oct 03, 2010 | Toshiba Satellite A215-S7444 Notebook
I have a new SATA hard drive to put into a used Toshiba M115-S3094 and I upgraded the RAM with the correct parts. The problem is when I plug it in, the power light shows blue but when I press the button to...
You problem is your memory. Try putting up the old memory and i'm sure that it will work again.
Possible Solution 1.
If you just add-up the new memory, try removing the old memory and just use the new memory because they might not have the same brand, speed, or something else.
Possible Solution 2.
If you are using only the new memory, you might want to try the old memory only and if it boots up again, you might have compatibility problem on your newly bought memory.
Hope it helps.
Jan 10, 2010 | Toshiba Satellite M115-S3094 Notebook
I need to perform a BIOS crisis recovery
please remove bios battery and weat 24 hours after install bios battery ,I am sure your computer work again.Never use new RAM because it is not adjust *********** board frquency or system bus.
Nov 23, 2009 | Toshiba Satellite A215-S7422 Notebook
Won't Boot up
im having a wierd problem my toshiba error 03-EEEE-0000 happened right after MYSTICALLY my atheros wireless wouldnt work so i formamtted wen i put in any windows CD it says BAD COMMAND.. same with recovery PLEASE HELP
Aug 13, 2008 | Toshiba Satellite A215-S7422 Notebook
Having trouble with memory upgrade for Toshiba laptop
I don't see anything about DDR2 I do see DDR SODIMM.
Kingston ( a company owned by Toshiba) has the specs you need for your pc. Here is the link:
http://shop.kingston.com/modelsinfo.asp?SysID=23890&mfr=Toshiba&model=Satellite+M55&SUBMIT1=Find
Jun 21, 2008 | Toshiba Satellite M55-S135 Notebook
We oreded one and got the other
There is no significant difference other than the build version with the latest build being the one you received and the best in that class of notebook, the A200 series.
You received what you ordered it is just the latest edition and you want that kind of service from Toshiba a great notebook maker.
Hope this Fixed Ya!
Worldvet
May 15, 2008 | Toshiba Satellite A215-S7462 Laptop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
